aaaalrite, heres what i got
i am using mkv files, and i am trying 2 extract the audio so i can put it into dvdlab pro and compile my dvd there
i had another topic where i tried 2 figure out how 2 extract the audio properly and convert it to wav format
so i thought i figured it out! i used mkextractgui to extract the aac audio streams, then i used rarewares.orgs aacdecdrop program to convert it to wav! then i used besweet to convert it 2 ac3
i thought i was home freee!! but then...i inserted the ac3 files into dvdlab pro and it says its the wrong frequency, 44.1kHz instead of 48kHz. boooo. dvdlab pro says the file is 44.1kHz, 448kbps, dolby 5.1, but only about 12 minutes long when it is in fact about 24 (i played it fine for the entire time in winamp) i tried to just go ahead n burn the dvd n c if my dvd player would play it, but during the compile stage and error came up saying it had to be 48 or 96kHz.
i've been searching the forums and the net like crazy, and i just can't find a way to convert my ac3 file into 48kHz! or even convert my wav to an 48kHz ac3 instead of a 44.1kHz!
any help would be greatly appreciated! i think im losing sum hairs here =P hahah~ thank you!
Make sure you don't have "downsample to 44.1kHz" (or something to that effect) checked in aacdecdrop. Since the aac file is already 48kHz it looks like you accidentally downsampled along the way. So if you still have the aac file, reconvert it to 6-ch WAV (I'm assuming this aac file is 6-ch), then convert the 6-ch WAV to 6-ch ac3. Again, make sure you don't downsample to 44.1kHz every time you convert.
If (I don't think this is the case but you never know) aacdecdrop only outputs 44.1kHz WAV, then use besweet or nero burning rom to get the wav out of the aac.Sorry, I had to go see about a girl -
Will the 6 channel surround effect from the AAC still be in effect in the resulted AC3? I'm just reading around so sorry for reviving an old thread.
I prefer to convert the AC3 to WAV, do the sampling change in good audio software like SoundForge, save the WAV, and then let an AC3 software convert back to AC3 (Besweet would work here too, with AC3ENC.DLL installed).
Need Help Converting Audio 44.1KHz LPCM flac to 48KHz LPCM + Add to DVD
By nagysaudio in forum AudioReplies: 2Last Post: 5th Oct 2010, 10:15 -
Convert at Low Bitrates at 48Khz in Stereo
By ashwin.terminator in forum Newbie / General discussionsReplies: 23Last Post: 23rd Jul 2009, 18:13 -
Convert stereo ac3 with bad channel to mono ac3
By chipsndukes in forum AudioReplies: 7Last Post: 5th Nov 2008, 12:23 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 20:22 -
AC3 on m4v not working, 48KHz AAC not working, 44.1KHz does?!?!
By dmjerbear in forum AudioReplies: 14Last Post: 11th May 2008, 19:23
