I was wondering if it is reallly necessary on movies that are all the way down to 92%? (DVD Shrink 3.2) I only left 5.1 English and Spanish subtitles on Kill Vol. 2 I was thinking of using Maximum Sharpness..
"What It Do"
Huh ????? -
Hey,
The quality settings do make a difference but don't use the default ones. Always use a maximum! In all honesty I can't see the difference between max sharp and max smooth, but on just sharp or smooth you get a black patchy effect on the movie which is really obvious when there's a light background. I'd perhaps just turn the quality enhancement off for a 92% compression. I tend to use it for anything under 85%.
Regards,
Kurtis Draven.I'm no failure! I've just found 57 ways that don't work... -
Hi sssax2003.
Unless you choose "Maximum Smoothness", DVD Shrink will only apply AEC if and when neccessary, so it's safe to leave any other setting on all the time.
It is difficult to quantify the influence of Deep Analysis when the compression ratio is > 90%.
If you really need to save time, only select it when the ratio < 90%.
Video Enhancement
By rckowal in forum RestorationReplies: 20Last Post: 13th Dec 2011, 13:54 -
Audio of video enhancement
By ginny02 in forum AudioReplies: 16Last Post: 19th Jun 2010, 14:56 -
Video Enhancement Software
By lazyturbo in forum Newbie / General discussionsReplies: 6Last Post: 25th Nov 2007, 16:14 -
Video enhancement software
By terryxpress in forum MacReplies: 4Last Post: 30th Aug 2007, 11:37
