I am new here and I really need your advise please. I captured my son birthday video clip and try to burn into DVD but got problem. The problem is it is burned succesful with DVD+RW but when I try with DVD+R it is failed. I did try to make a copy from the DVD+RW (that is OK) into DVD+R and got same problem (which is failed). I can not remember exact error but something like "can not end-to-end disc".
I run Window XP with 2.6 GHz and 512 MB. I have this system for about a year and it is OK until now. Please help. Thanks.
Results 1 to 9 of 9
what make & model is your DVD Writer?
Do you have Norton Antivirus 2004? if so disable it during the burn process. -
It sounds like a media problem. What brand of dvd are you using? It would be helpful to fill in your computer specs that way it's easier to help solve your problem.
What other software are you using besides NERO? -
More info please, the make and model of burner, media brand.
But here's one bit of advice i will give you, grab a copy of Stomp RecordNow max, it dumps all over Nero for stability.
My burn failed with Nero too - or should I say it looked ok on the software when burning to Ritek blank DVD-R but the DVD disk created is not recognised by Sony or Panasonic standalone players.This is my first attempt with Nero and I'm totally confused.It's as if the disk isnt finalised - because it will play back on the PC DVD re-writer.I thought a DVD-R burned on my PC DVD-writer should play on a standalone player.
I must be missing something basic-Help? -
Im trying to copy a homemade movie from a dvd-r to a dvd+r using Nero and it says I must have a dvd-r to do this and it wont let me continue.. I also am using blank RIDATA media dvd+r discs.... any info greatly appreciated...
I have Lite-on for burner. I don't have norton but i have mcafee 8.0.
What brand of dvd are you using? I am using Platinum +R
I just try to burn again on another movie and it works on DVD +R. I am not sure what cause the problem. Thanks for all reply. -
what is the model number of your liteon burner? it's a known fact that LITEON burners prefer DVD+R MEDIA than DVD-R MEDIA. never heard of platinum +R media. is that TDK? what is the exact media code? check by using DVDINFO PRO or DVD IDENTIFIER. you can download them from the tools section to your left of this site.I have Lite-on for burner. I don't have norton but i have mcafee 8.0.
LITE-ON DVD+RW LDW-401S. LITE-ON DVD+RW LDW-401S supported DVD+R. Platinim is the name of media (just like TDK, Maxwell...). Media code is 001 (i got this info on the disc that i was able to burn). When i put blank disc it did not give me media code. Thanks
Nero - Compliance test failed? whats up w/ this?
By BRYAN_B28 in forum Authoring (DVD)Replies: 11Last Post: 2nd May 2012, 02:13 -
8gb dvd burning failed
By renz_007 in forum Newbie / General discussionsReplies: 8Last Post: 8th Apr 2011, 10:08 -
nero burning failed
By KristijanR in forum Newbie / General discussionsReplies: 1Last Post: 6th Jul 2009, 02:10 -
Nero failed burning DVD
By DuBsTaR in forum Newbie / General discussionsReplies: 3Last Post: 6th Jan 2008, 15:15 -
Nero 7 data verification failed....?
By LoneWolf1038 in forum Newbie / General discussionsReplies: 3Last Post: 21st May 2007, 09:06
