i encode with tmpgenc all the time and it works fine and now it isnt encoding the audio properly. it encodes the video just fine but the audio is just on for a second and then the rest is silence![]()
i need help anyone know whats wrong, maybe a codec problem or something. the sources file is .avi
try change the directshow priority
or you can encode the audio separate with something like ffmpeggui, belight and after join it with the video(multiplex)
or separate the audio in the video to wav and use it as the source in the tmpgenc, www.videohelp.com/virtualdubaudio -
thanks for replying but i have figured it out now. i have green arrow in the system tray which has lots of options and stuff so i thought i would look at the audio options (its codecs). the audio in the avi is mp3 so i disabled the mp3 decoder and i was amazed that it worked because i thought it wouldnt.
TMPGEnc Video Master Works audio problem creating bd25
By necron99 in forum Video ConversionReplies: 0Last Post: 29th Apr 2012, 19:52 -
MiniDV Video & Audio Problem - Corrupted, Detiriorated, Missing Audio
By 4truce in forum Capturing and VCRReplies: 14Last Post: 4th Aug 2011, 06:36 -
TMPGenc Audio Problem
By Iwan2learn in forum Authoring (DVD)Replies: 5Last Post: 13th May 2009, 09:27 -
Audio Problem using AVISynth and TMPGEnc Xpress
By 1980sumthin in forum Video ConversionReplies: 10Last Post: 27th Jan 2009, 05:27 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41
