I was trying to make a SVCD slide show disc using mpeg2's (generated in TMPGEnc using Virtual PC) and VcdToolsX. However, I can't seem to add more than one mpeg at a time.
Does anyone know if VcdtoolsX can handle more than one mpeg?
Thanks in advance
This is a feature that I will implement in the future. If you want to burn the SVCD, you should be using toastXAimage function tab. Then you could simply add more sequesnces in the XML.
But it will be implemented. I just have to get some knowledge in TableView object in COCOA.
Also Im working on a XML generator for VCDs and SVCDs. If someone are interesting in that one please mail me and I will put it out on the net to.
Jesper Nilsson, GNU vcdtoolsX developer -
I encoded SVCD compliant mpeg2s, authored a xml file, but vcdToolsX 0.2 toastXAimager stops as soon as I start it. All other functions work as expected.
Any clues as to what kind of problem to look for? Can not get vcdxbuild (vcdimager on VPC) to run.
G4, OS 10.1.1 -
The most common problem is with the XML-file. The path to the mpeg must be exact and not relative.
Try vcdImager on osX (CLI app), it will give you more error output.
Remove multiple tracks from multiple MKV files
By accoutabc in forum Video ConversionReplies: 3Last Post: 7th Aug 2011, 11:50 -
Merging/Converting Multiple M2TS files to MKV With Multiple Audio Tracks
By Nicholas S. Folsom in forum Video ConversionReplies: 1Last Post: 13th May 2011, 18:34 -
Deinterlace first or multiple times? Encoding source to multiple formats.
By greyfalcon in forum Video ConversionReplies: 1Last Post: 12th Apr 2011, 04:39 -
Batch hard encode multiple language srt to multiple videos
By clonius in forum SubtitleReplies: 4Last Post: 15th Jul 2010, 14:06 -
how do I join multiple avi files with multiple audio tracks?
By helloguys in forum EditingReplies: 1Last Post: 26th Dec 2007, 02:28
