Could use some help:
I have about 10 8mm analog tapes (not Hi8) that I want to capture to MPEG on my PC to edit and then produce DVDs (I do have S video and audio inputs), but the camcorder is completely broken.
So the question is what method would you suggest to capture?
- purchase an old 8mm analog camcorder to replace the broken one
- purchase a digital camcorder that I can capture via USB (A/D conversion performed by the camcorder)
- since the PC is a Vaio and has "I link" (whatever that is) obtain some equipment that can capture that way.
Like I said....help!
Thanks in advance....by the way what ever I purchase I will not be using the camcorder again, so expense is a factor.
Allen
Another option would be to borrow a camcorder or check the local photo stores to see if one of them rents camcorders that you could use. A little more expensive would be to pay for a transfer service to DVD.
Capture Analog 8mm Video 8 Tapes to DV - What equip will produce best Qual
By koop in forum Capturing and VCRReplies: 7Last Post: 4th Apr 2012, 23:36 -
Decent econmical way for converting 8mm (analog) video to H.264 files?
By salils in forum Capturing and VCRReplies: 5Last Post: 26th Dec 2011, 15:17 -
Best way to convert analog 8mm tapes to digital
By charliedog in forum Newbie / General discussionsReplies: 7Last Post: 29th Nov 2011, 02:15 -
copying analog 8mm to mac using sony digital 8 and firewire
By iampammyb in forum MacReplies: 4Last Post: 15th Nov 2008, 00:15 -
8mm to Digital - Capturing w/ DV Camcorder
By tripecac in forum Capturing and VCRReplies: 61Last Post: 9th Jul 2008, 18:51
