hi,
I use MATROX RT2500 along with Premiere 6. I want to export the timeline using Mpeg IBP to be authored on DVDit.
matrox file converter forces my export settings to "recompress"... and the outcome is a fast forward looking clip!...
is there a way to uncompress this clip to look normal again?
if not...when i unclick the "recompress" and try to export..then use the converter...it fails saying that it cannot convert mpg ibp because data rate greater than 7 Mbits/s
what's the solution?
thanx
