Hi All,
I've inherited a G4 450MHz Sawtooth, and intend on using it as a PVR / Media Centre type device but have a few questions.
First - does it have enought grunt? I'm assuming that whatever capture device I get will need to do the MPEG encoding, but is 450MHz enough? It does have 768MB RAM which is good.
2nd - Is it best to go to EyeTV or is there an Internal PCI TV Tuner / MPEG capture solution that works on MacOS X, and also has programmable PVR-style software. I'm in Australia, and as such investigating using DVB-T Digital Television a la the EyeTV 410, but I suppose Analog broadcast is fine too.
3rd - Is traditional 802.11b Airport fast enough to stream video to an EyeHome (or similar) or will I need to upgrade it to G. There's a possibility it will be hardwired to the EyeHome but not 100%
Cheers,
Here's what you need:
http://www.miglia.com/products/video/alchemytv/
I'd suggest the G4/G5 version... Anyone have this? Any comments? The EyeTV might be better for some things, like watching content from your computer on the TV using EyeHome or whatever.I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
If you are interested in DVB digital TV check this out:
http://www.defyne.org/dvb/
Best video deck to play S-VHS tapes shot on a Panasonic AG 450
By fuzzblaster in forum Newbie / General discussionsReplies: 0Last Post: 15th Aug 2010, 07:11 -
How to Compress 450 MGB MPEG2 Video by 75% ?
By videomike in forum Video Streaming DownloadingReplies: 4Last Post: 11th Jun 2009, 10:57 -
PVR files on a PVR formatted disk
By keithy in forum Newbie / General discussionsReplies: 2Last Post: 22nd Apr 2009, 08:26 -
Just purchased used Lenco TBC 450.....Anybody got info?
By mbself in forum RestorationReplies: 0Last Post: 5th Feb 2009, 19:22 -
Hauppauge PVR-350 vs PVR-500MCE
By dphirschler in forum Capturing and VCRReplies: 1Last Post: 11th Mar 2008, 09:04
