Results 1 to 13 of 13
  1. hello guys!!
    I have a big problem here
    Im trying to burn a downloaded movie to dvd-r & listen to it with my dvd player
    First off i Burn the .AVI movie with NERO vision ... i choosed long play option so it lets me burn full movie set 2pass VBR for better quality &i choosed 16:9 since the downloaded movie itself was in splitscreen (wide sreen with the 2 bars) so i didnt want to put 4:3 like default was putting
    now i burned it all sucessfully now i don't see the DIVX icon in the bottom that means it stretched & now image is bigger & frustrating please help me!!!
    Jun 2004
    Ferrara-Italia
    you better post this in the conversion forum. Anyway, you can't simply resize choosing 16:9 instead or 4:3 or whatever. You need to know what your source resolution is, its display aspect ratio (being an AVI it's just square pixels), set your destination resolution and display aspect ratio and do your calculations accordingly. Not knowing this data I can't be of much help. You can start with reading some avi to dvd guides and especially a "how resolutions and aspect ratios work and how to resize" guide. Look for one written by DJRumpy in the guides section.
    Once you know what you're doing, all it takes to calculate the final resolution is 1 minute and windows calculator, I kid you not!
    I swear I've answered like a dozen how do I resize questions in the last few days lol.
    Sorry, I had to go see about a girl
  3. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    Originally Posted by hayabusa
    option so it lets me burn full movie set 2pass VBR for better quality &i choosed 16:9 since the downloaded movie itself was in splitscreen (wide sreen with the 2 bars) !!
    If the original file plays with the bars included (in other words if you view it your editor and the bars are part of the video) set the display to 4:3. That would be a 16:9 movie overlayed on a 4:3 format. An additional suggestion would be cropping the bars and then set it as 16:9.
  4. i don't get it ....
    what programdo i need to use to do this thing NEro vision doesnt allow me to make this kinda stuff
  5. A good reason not to use NeroVision. Get TMPGEnc.
    "Rarely is the question asked: Is our children learning?"
    George W Bush - Moron
  6. what program do i need to burn it by after & ..... what settings do i need to apply ..... i have tmpgenc
  7. In TMPGEnc there is an option called "clip frame" and you'll need to use this to mask off the black bars. When that's done you'll be able to set the encode size to 16:9 and when you convert, your footage will be sized correctly.
    Of course if you only have a 4:3 screen to watch it on you're better of leaving it 4:3.
  8. i get you but what color do i need to frame it ? (will it appear on the screen?)or onl,y guide me since the bars are already black:P
    also how much do i need to Frame it ? theres so many settings out there i never done this .....
    I think my video is 640x288
  9. also theres an option besides it it says arrange settings do i need to put that full screen / full screen keep ration/ratio2 / center custom size/ center?
  10. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    To answer your quetion you really need to say whether the black bars are part of the video. Are they visible in your editor?
  11. well I dont see them... but in ''media player they are there it's weird......
    I really dunno what to do ... im only missing some few adjustments to have perfect fit on my tv since my DVd was on mode (16:9) so thats why it was fucked as **** but i set it back to 4:3 it's 100x better but .... still missing few like the credits last name (last letter is hidden on the right side)
  12. Okay, the reason that it's cutting off the letters is due to overscan. This can be fixed in TMPGEnc by using the center custom size feature. You'll have adjust this to add on a black border around the video. If you are encoding at 720x480 try entering in 704x480 for a custom size. If that still isn't enough you could try 696x472. The reason for this is to allow the black borders to be cut off instead of credits or subtitles.
    You should also check out the clip frame option. Look at the preview and if you see black bars on top and bottom cut them off and add masking. Those bars will chew up a lot of bitrate so definitely cut them out.
    Jun 2004
    Ferrara-Italia
    Do a gspot (find gspot in the tools area) scan and report back what it says about your file (especially resolution!). Without knowing the source resolution it's kind of hard to guess how you should do the resizing!
