Can anyone recommend a good VHS head cleaning tape. I have three different (wet type) ones. You are supposed to put a few drops into the tape and then play the tape for 20-30 seconds. However all three tapes will shut down all 4 of my VCRs in less then 5 seconds. The tapes recommend if that happends to use the RECORD function, but alas it does the same thing.
I have one JVC VCR, one SEARS and two Optimus's (Radio Shack).
TIA[/url]
Personally I use a Sony never had a problem. JVC is also great, maybe yours is defective? If not try Sony there pretty hassle free.
The three head cleaners have the same effect on all of my VCRs and not just the JVC.
I've always done it the old-fashioned way:
Pop the hood
Alcohol on paper towel on all the heads and rollers
Demagnetize all heads and tape path
denatured alcohol from hardware store is best.
A cleaning cassette should work in one of the modes, play, ff, rec, etc. Otherwise take it back. Don't clean your heads if they don't need cleaning. -
Try setting the audio to "Linear" in the set-up menu, this works for my old Sanyo. When done, return to hi-fi audio.
Dirty Head or Degrading Tape?
By nazopo in forum Capturing and VCRReplies: 7Last Post: 7th Aug 2010, 23:50 -
VCR Head Cleaner & More
By SHIKISMOM in forum Newbie / General discussionsReplies: 2Last Post: 15th Apr 2010, 10:26 -
Hi8 tape playback problems after head servicing
By pkn25 in forum RestorationReplies: 6Last Post: 26th Nov 2009, 11:52 -
How to fix blocks on DV tape produced by faulty head.
By kurbads in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 21Last Post: 25th Mar 2009, 07:55 -
VHS Head Cleaning -- How do I know if the VCR needs it?
By KeepItSimple in forum RestorationReplies: 20Last Post: 23rd Mar 2008, 22:10
