Ive Downloaded Windows Xp And when i try to open it says win xp is not a valid win 32application anyone know whats up?????????
please choose a better subject next time.....
Read the manual how to install win xp! or do a search on http://www.google.com for some basic windows installation help -
Try here:
www./dev/0.com
If that link doesnt work... (it probably wont but hopefully will)
I presume that what you have done is to downlaod WinXP from Morpheues or other p2p - what you have my friend is probably an .iso, an image of a CDROM. With this WinXP.iso or whatever the name is, you burn it to a CDR. Then you put it in your CDROM drive (Read, Coffee holder) and set your BIOS to boot from the CDROM... then you begin an install.
Failing that, Email M$ and ask them to help. Subject:"Help me install a WinXP.iso that I downloaded".
I am sure that they will help. -
I don't think Microsoft will be to happy because you just downloaded Winodws XP illegaly while others are paying for it. Anyway I can help you install it.
1)Go to where its located and change its extension from .exe to .iso
2)Get CDRWIN and burn it the .bin image onto a CD-R
3)Now insert that CD into your CD-ROM drive and installation should start.
Hope this helps you,
I only dream in black & white...
MSN: paschendale@gmail.com
Some help needed with multiAVCHD
By VOYAGER2009 in forum Authoring (DVD)Replies: 6Last Post: 20th Jul 2011, 11:19 -
[ HELP NEEDED ] BD-ROM to BD-R 25 with BDRebuilder: how much CPU is needed?
By Tyrexionibus in forum Blu-ray RippingReplies: 1Last Post: 28th Oct 2009, 12:27 -
Subs When They Are Needed
By urb1972 in forum SubtitleReplies: 1Last Post: 28th Feb 2008, 15:03 -
Hack needed
By chisholmh1 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 31st Dec 2007, 10:32 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 18:30
