A friend of mine wants to split or better span and burn to CDR an SVCD
What software should he use to split and burn if possible
Thank you
TMPGEnc has a section called MPEG Tools and in that there's a section called Merge and Cut that can cut MPEGs to any size or runtime you want. You would basically add your file, then set its start point at the start and end point at about half way. Process this. Then add your file again, but this time set the start point to about 3 seconds before the endpoint of the first file and the end point at the end.
If in doubt, Google it. -
...but beware that cutting mpegs is a tricky business - Only app I feel I can trust for cutting in mpegs is Womble mpeg VCR. Every other attempt I've made has either not worked at all, or resulted in sever sync problems.
OTOH, it seems a little odd, creating a SVCD file that won't fit a CD?!?
/Mats -
thank you both
I do have a copy of Womble mpeg VCR
Then again it is not my SVCD so I can't tell you about the particular of such large file
My peer speaks Spanish only and I just doing him a favour to find out how to covert a SVCD successfully
I may ask this question above and hopefully come back with a more appropiate answer
Why are cdr burn rings lighter than dvdr burn rings?
By yoda313 in forum Newbie / General discussionsReplies: 4Last Post: 27th May 2010, 17:55 -
How to burn AVI files onto CDR?
By doofdoofdude in forum Newbie / General discussionsReplies: 2Last Post: 18th Apr 2008, 10:08 -
burn vob into cdr
By pcb in forum Newbie / General discussionsReplies: 10Last Post: 18th Feb 2008, 12:28 -
How Can I burn a 90 min data CDR Image to HD Folder
By SCDVD in forum Newbie / General discussionsReplies: 1Last Post: 15th Feb 2008, 19:48 -
How do I split a SVCD
By VoXiSo in forum EditingReplies: 1Last Post: 4th Feb 2008, 15:14
