I have about 3 hours worth of movies, and I want to fit them onto a dvd+r. What would you say is the lowest bitrate I should encode them with in TMPGEnc 3.0 Xpress? I'm currently trying to encode them each at a constant bitrate of 4000 kbits/sec, and I know I can go lower, but I don't know how much bitrate I should encode them with to fit them all on one dvd+r and still have a good/average quality.
I am not sure if it is the same for TEMPGEnc3, but on 2.5. when you encode them with TEMPGEnc using the wizard, there is a percentage guide and selecting the DVD as the destination, you should be able to get an idea of what bit rate for any particular film will fit onto how much of the DVD.
For example, if each film is one hour long, then aim at making each film about 30-32% of the total DVD. The bit rate will be calculated for you.
Hope that this helps.Cole -
Thanks, but thats not what I want to know. I want to know the lowest you can go for the bitrate to still get a good quality.
read https://www.videohelp.com/forum/viewtopic.php?t=245249&highlight=352x480
and please post converting in our converting forum. moving you. -
Originally Posted by frankusho
There's no "magical formula" to work this out. It depends on the type of footage, the quality of the source, and the encoder settings, but to name a few. The time you wish to put on 1 DVD determines the bitrate you must use. The bitrate you need to use determines the resolution you should use.
3 hours on 1 DVD needs a video bitrate of about 3150kbps with 224kbps audio, and no menus. If you want menus you need to reduce this to about 3000kbps or so.
Cole had a very similar question to this, and this is what I posted in reply:
Originally Posted by jimmalenkoIf in doubt, Google it.
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 07:38 -
Question about bitrate, spikes and Bitrate viewer
By sasuweh in forum Authoring (DVD)Replies: 3Last Post: 25th Oct 2010, 15:01 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 18:17 -
Most compatible codec, Lossless bitrate, and max bitrate
By sevenlayercookie in forum Video ConversionReplies: 2Last Post: 6th May 2009, 20:43 -
Low bitrate source to High bitrate target
By sameerdhiman in forum Newbie / General discussionsReplies: 2Last Post: 7th Nov 2008, 23:54
