I have tried about 5 times to encode an ~700MB .avi file (MPEG4, 512x384 video 192kbps/48000Hz audio) file to MPEG-2(352x480)/AC3 audio. I have tried using the quick presets then fiddling with audio parameters, and not using presets and just entering the parameters manually, and each time after 24 hours of encoding (yeah, my machine is SLOW) I get a video file with the right video, but mp2 audio. What's the deal. Why will it not let me get AC3? I wouldn't case too much, but
1) I swear it did not use to do this, and
2) the mp2 is not the right size (5 minutes missing from the end and not loses sync in the middle
What gives?
Are you possibly using the "Decode with mplayer" option? If yes, it only supports mp2 currently.
As usual, you hit the nail on the head! (maybe there should be an error message alert or the option for AC3 grayed out if the mplayer option is being used?) The issue that caused me to chose that option, however was that the quicktime codec for some reason was generating a file that DVD studio pro was not able to import. Perhaps I will try to keep the elementary streams from the quicktime results and try those.
As usual, thanks a lot.
My normal procedure is to encode with the ffmpeg MPEG2 codec and not concern myself with what materializes for an audio track. I never use the Decode with QT option. If the AVI has an AC3 track that I want to use, I then open the original AVI, set the 'Movie Audio to AC3' preset, select 'passthrough' and use that audio in DVDSP. You do have to change the extension though. It gives something like .avi.ff.cc, change it to .ac3 and all is well. If the audio track is something else, I open the AVI in QT Pro and export an AIFF for A.Pack. Works everytime.
Mpeg Streamclip suddenly refuses to create DV's
By Gretchen in forum Video ConversionReplies: 3Last Post: 29th Oct 2011, 14:53 -
AVIsynth refuses to work anymore... Plz help!
By Nagashi in forum Newbie / General discussionsReplies: 3Last Post: 24th Dec 2010, 17:44 -
ADPCM Format ? WMP refuses to play
By drwho in forum AudioReplies: 2Last Post: 30th Oct 2008, 23:28 -
Luxor DV404 refuses to recognize DVD:s anymore
By drDubbelklick in forum DVD & Blu-ray PlayersReplies: 1Last Post: 19th Jul 2007, 16:29 -
HTPC refuses to boot after current failure
By Jacobus Serpenti in forum ComputerReplies: 22Last Post: 19th Jul 2007, 03:41
