On my laptop i had an older version of AVG antivirus. I upgraded to SP2 and the older version of AVG worked fine. I finally downloaded the latest version of AVG and my laptop wont boot. It hangs before it starts windows. At the boot screen if i select 'load last known working config' then windows will load but AVG is disabled. The XP shield pops up saying AVG is disabled and that i need an antivirus. Has anyone experienced this?
If the other version was working, you might want to go back to it.
I just downloaded AVG 7X to replace the 6X version and have no problems. I'm running it on a laptop with SP2. You might reinstall the program. Sounds like it is set to scan at bootup and is locking up there. You might try safe mode and uninstall it, then reinstall after a reboot.
AVG 8 updates?
By wulf109 in forum ComputerReplies: 2Last Post: 3rd Feb 2009, 09:49 -
AVG trouble
By romanstopme in forum ComputerReplies: 2Last Post: 31st Dec 2008, 11:45 -
AVG kills XP
By stiltman in forum ComputerReplies: 13Last Post: 11th Nov 2008, 22:04 -
AVG problem
By Tbag in forum ComputerReplies: 3Last Post: 12th Aug 2007, 16:12
