I am having a problem with crackling audio on capture.
The signal path:
JVC HR9800U hi-fi playback > RCA cables > Canopus ADVC-100 > Firewire > Vegas Video
I have been going through a list of causes to fix and haven't hit on the right thing yet. I hear the crackles while monitoring the capture and on playback as well. There are no dropped frames on capture. There are no other programs or background processes running. I have 100GB free hard drive space, 1GB RAM, 2.4GHz processor. I captured the audio again using a different signal chain JVC > RCA Cables > Soundcard and the crackles were still there. A new, different VHS tape had the same crackles. When I zoom in on the waveform you see a little sharp upstroke... they sound kind of a like a vinyl record.
Does this mean that the audio head in my VCR is dirty maybe? Suggestions are welcome.
Try 2 things:
1. Connect your VCR to an amp and speakers if you have that and play the tape. Are the crackles still there?
2. Try another VCR with the same 2 tapes.
That should tell you if it is the VCR.
Is there a capture utility like tunebite that will capture 5.1 audio?
By yoda313 in forum Capturing and VCRReplies: 5Last Post: 18th Dec 2015, 02:45 -
How to capture audio only
By bigbomber5 in forum EditingReplies: 2Last Post: 1st Sep 2010, 14:38 -
What about audio capture?
By Fryster in forum Capturing and VCRReplies: 3Last Post: 25th Dec 2009, 09:47 -
capture not getting audio
By bbxrider in forum Capturing and VCRReplies: 3Last Post: 7th Aug 2009, 13:00 -
How to - Capture DVD 5.1 Audio - Coaxial vs. RCA Audio
By JBredensteiner in forum Capturing and VCRReplies: 3Last Post: 13th Jul 2007, 12:46
