  1. Member Gargoyle's Avatar
    Jul 2001
    Southern New Jersey, USA
    I have several TV episodes in .AVI format – captured from satellite tv @ 720x480, HuffYUV compression; the goal is to burn them to DVD with 3 episodes (approx. 120 minute total) on each disc.
    Does anyone have an opinion on which method will give me the best results:
    Encode each episode as MPEG2 at maximum DVD bitrate, import 3 episodes into DVD authoring program, then compress (DVDShrink, DVD-Rebuilder, etc) the output to fit on 1 disc.
    OR
    Calculate the bitrate so 3 episodes will fit on 1 disc, then encode each using that bitrate, author, and burn.
    Basically, I guess I’m asking if the quality of final output will be better if I encode at a bitrate that will fit 3 episodes on 1 disc, or if I should encode each episode at the maximum bitrate spec for DVD, then compress the output to fit on 1 disc.
    Any thoughts – suggestions – opinions?
    You can't fool me, I'm a moron!
    Do it correctly the first time.
  3. Originally Posted by lordsmurf
    Exactly, use a bitrate calculator.
  4. ditto. bitrate calculator.
    The distance between genius and insanity is measured only by success...
  5. Member monzie's Avatar
    Nov 2003
    The Village
    As above, your only wasting time re-encoding (or "transcoding") the video back to where you would be if you used a birate calculator in the first place....the end result is IT STILL HAS TO BE OF A SIZE TO FIT ON A DVD.
  6. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I agree with all 4 above. Do it right, first time. 120 minutes is an average of about 4800 kbps for video given 224kbps audio, so I would look at either 720 * 480 2-Pass VBR max 9000, ave 4800, min 1000 or 352 * 480 CBR 4800.
    If in doubt, Google it.
