I've been reading all about what to do regarding lost frames during capture, but I don't know how to see if, and to what degree I have this issue. I'm new at this and only want to capture .avi from my camcorder to edit and burn to DVD. I have the steps down, but I just finished my first capture and want to know if I have lost any frames before I edit and encode.
Also, when I capture from the digital camcorder, do I still choose a "resolution"? I used Ulead 5.0 to capture and I don't remember selecting a resolution.
Thanks.
Your camcarder is digita, so I assume DV. Therefore are you 'capturing' via firewire. If you are (and you should be) then it is not really capturing, simply a transfer of data from the tape to your HD.
Your capture app should inform you of lost/dropped frames during the capture procedeure. You don't need to select a resolution as DV is a fixed resolution (720 * 480 NTSC, 720 * 576 PAL).
Virtualdub VCR capture no dropped frames but 5400 inserted frames in 1 hour
By suloku in forum Capturing and VCRReplies: 12Last Post: 17th Aug 2011, 22:33 -
need help unblending previously blended frames rather than dropping frames
By BilboFett in forum Video ConversionReplies: 15Last Post: 12th May 2011, 21:15 -
mencoder: seeking to frames (or cropping start frames)
By manchurian_candidate in forum LinuxReplies: 3Last Post: 13th Dec 2010, 08:53 -
VLC Media Player - "Lost Frames"
By Ancalagon in forum Software PlayingReplies: 3Last Post: 18th Feb 2010, 05:57 -
inserted frames without dropped frames in VirtualDub capturing VHS
By whschlebaum in forum Capturing and VCRReplies: 0Last Post: 23rd Aug 2007, 20:59
