SVCD to DivX
or any other suggestable solution
without compromising colors
I have two english language SVCD files
I can see them correctly in PowerDVD
I have several subtitles files
most of them in .srt format
I've seen there's the possibility to convert
the .srt files in vobsub format
but this transforms subtitles in bitmap images
This is probably good if you play the file
from a hardware player and you'd like to
change between different subtitles...
but if you play the file on a pc and you'd
like the files to fit on CDs i think (correct
me if i'm wrong) that's not the way to go...
Thought about converting SVCD in DIvX
https://www.videohelp.com/avi2divx.htm
but, as is pointed out in this page
and in another forum message,
that creates colorspace problems
if you do it in virtualdub...
> If your source is MPEG2(SVCD or DVD MPG files)
> or VOB you must use the Virtualdub-MPEG2.
> It's suggested to use fast recompress mode
> for video to avoid a useless double conversion
> between color spaces... RGB to YUV to RGB again
> BUT, it's also pointed out that if you are converting
> from SVCD you MUST use full processing mode
> because to resize video you have to use
> virtualdub filters ...and they work only adopting
so
if you are converting from SVCD
you must resize
so
you must pass through double useless color conversion
and you lose color details...
Now
these are video files
about art history and i have to use them
in a university course
(I'm not the professor but she asked me if
i could bring the files...)
I have to find a way to convert SVCD to DivX
possibly without losing color details...
Have tried not to do the resize thing
with virtualdub filters
but trying to serve a file with avisynth.
Virtual dub opens the file and i can
navigate through it but when i try
divx conversion there are always errors
most frequent:
"Cannot start video compression
The source image format is not acceptable
(error code -2)"
what does this mean?
I've tried a lot of things
After two days...
virtualdub-MPEG2 doesn't complain
and starts saving the avi/divx file
only if i ask a
video fastrecompress,
compression > divX > 1-pass
BUT with the fastrecompress i cannot
trigger the resize filter...
Isn't "the source image format" the same?
indipendent from what i'm asking virtualdub to do?
Isn't "the source image format" the same indipendently
from working in fastrecompress or full processing modes
from asking virtualdub to filter at some point of the chain
or to touch the stream only for the compression?
Am i missing something?
Any help appreciated!
dee
Closed Thread
one topic is enough. just bump your old topic if noone replies after a few days.
https://www.videohelp.com/forum/viewtopic.php?t=245750&highlight=
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 09:11 -
Reconverting Divx videos to smaller Divx files.. strange resolution
By arcooke in forum Video ConversionReplies: 2Last Post: 19th Jul 2011, 02:35 -
Beta Announcement: DivX Plus Web Player 2.1, DivX HiQ and HTML5 Support
By porfitron in forum Latest Video NewsReplies: 1Last Post: 23rd Nov 2010, 12:20 -
Conversion divx to svcd gives Choppy Playback
By Soixante in forum Video ConversionReplies: 2Last Post: 17th Nov 2009, 06:25 -
Make an unplayable Xvid/Divx video play in a divx standalone Player
By AllenGorden in forum Newbie / General discussionsReplies: 4Last Post: 31st Dec 2007, 17:25
