    Apr 2004
    The bottom of the planet
    And more to the point, do I actually need it?
    "It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..."
  2. DVD Rom drives do NOT have SPDIF (that I have ever seen anyway).
    Some Soundcards have SPDIF.
    You only need it if you want to output raw Ac3 or DTS to an external decoder/amp
    http://whatis.techtarget.com/definition/0,,sid9_gci213474,00.html
    Jan 2004
    Canada
    Look at the back of the drive. If you find a two male pin (receptable) that says D (for data) and G (for ground) that is a SPDIF. You have to be carefull though because this SPDIF is at TTL level. You have to use a circuit to make is SPDIF standard (0.5 volt). Do not plug spdif output off the DVD-ROM straight to Receiver spdif input.
    Most of newer sound cardz however, like SBLIVE,AUDIGY, has a TTL spdif input.
