I'm putting old documentaries to DVD with WizCap, which converts VHS to MPEG2.
Sometimes during the show's end credits there is unwanted voice-over.
I want to edit-out the unwanted voice-over and keep the end credits images.
At what point should I attempt that audio editing so that I have the best chance of rendering the changes and keeping video-audio synchronized.
Please walk me through the steps of conversion, editing, rendering, whatever is required to do the job.
I have Windows XP, and have had no problems with my CPU or video card during basic work done with DVD Decrypter and DVD Shrink.
I have TMPGenc but I'm still reading the docs, haven't used it yet.
Thanks for any and all help.
I've done this quite a number of times with TMPGEnc DVD Author. First figure out how long your credits are and create an MP2 audio clip that long that is just silence.
Load your footage in as a track and edit off the end credits. Now load your footage again as part of the SAME track and choose your silence file for it's audio track. To finish it off go in and edit off all the video BEFORE the credits.
When you output this Author will join the clips as one seamless track and the voiceover will be cut off without messing up your sync. Of course you can choose to use music instead of silence, it's up to you.
Editing TiVo Recording (MPEG2/AC3) with MPEG Streamclip loses audio
By DarthEd in forum MacReplies: 15Last Post: 4th May 2012, 07:28 -
Editing and effects advice.
By dz302 in forum EditingReplies: 9Last Post: 19th Jul 2010, 01:49 -
Advice on a new audio/video system(I need advice and direction)
By hellfire45 in forum Newbie / General discussionsReplies: 1Last Post: 14th May 2008, 23:20 -
editing software advice
By tommcd64 in forum EditingReplies: 4Last Post: 27th Oct 2007, 19:44 -
Advice on editing software
By Newbie 332 in forum EditingReplies: 8Last Post: 25th Jul 2007, 08:57
