i'm trying to add subtitles to an avi file and then convert it to mpg format but i'm encountering a few problems. i have a srt file and from the guides i have to convert it to ssa then feed it into virtualdub. but when i try to convert it with the srt2ssa program it gives me an error saying input file error #1 and then it says job done ?!?!?! really weird so i try to encode it anywayz with the tmpgenc and no subtitles are showing up!?!?! someone please help !!!
Have you tried using Subtitle Workshop for your conversion? It works pretty well.
In return, could you recommend some good sites to find Chinese subtitles? Thanks. -
well i find my chinese cubs mostly from emule ........
i hope that helps -
You could try DVDSANTA.
This was taken from one of the comments posted here,
"Fabulous program if you want burned in subtitles. Make sure its a srt file, the same name as the movie and in the same folder. DVDSanta will automatically make a file with the subtitles.
Very useful as well if you have a movie split over two avi files. Drag and drop and press a button and finished. It even keeps 5.1 surround sound intact. Not really fast but the quality is very good if not excellent. "
I have not tried this yet, but I use DVDSANTA and am very happy with it. -
I can confirm the subtitles DO get burned into the DVD created by DVD Santa. I'm on version 3.40 build 4860.
As EvilWizardGlick states just make sure the SRT file is in the same folder as the movie file (whatever type it is, avi , ogm, etc) AND that it has the exact same name.
You might need to rename the SRT file as it generally comes with a slightly different file name to the film file. i.e
<file name>-english.srt
Chinese subtitles require Chinese font on the computer?
By Haopengyou in forum SubtitleReplies: 0Last Post: 24th Mar 2012, 11:04 -
How to I convert Chinese srt to HD subtitles?
By TetsuSama69 in forum SubtitleReplies: 4Last Post: 31st Dec 2010, 17:58 -
Converting traditional Chinese subtitles to simplified
By Haopengyou in forum AudioReplies: 1Last Post: 20th Jun 2010, 10:40 -
subtitles showing like chinese
By forare in forum SubtitleReplies: 1Last Post: 20th Aug 2009, 08:20 -
Adding chinese subtitles to original DVDs
By viewpoint in forum SubtitleReplies: 4Last Post: 17th Aug 2009, 11:08
