Hi,
I think I am going crazy - tell me if I am or not.
It is possible that when encoding to WMV - that the file created will be different depending on how muhc of a load is on the PC? (specifically with VBR?)
I am working on a project where I am converting an MPEG2 DVD source clip =(pulled the VOB off the disk, renamed it .mpg - used tools in tmpgenc to cut the piece I want) - and I am converting it to smaller size files. MPEG1 MPEG2 and also WMV
I am using the new Windows media encoder (find that other products are just not working - FX video converter/ X video converter etc.)
Here is the crazy part - when I do the EXACT SAME ENCODING - of the exact same file - to a WMV with the same (standard) settings and I do it several times. My resultant file varies tremendously. It seems to me that it is based on how busy my computer is during the encoding. The busier it is - the smaller/worse or a file it creates/the less kb/s in actual etc.
This is mind boggling to me. I can understand it taking longer to produce - but how can it give me WILDLY changing results?
Anyone seen this before? do I need a dedicated machine to do the work in WMV. I have never seen this with Mpeg encoding (capture yes encoding no)
thanks for any feedback
Allen
No, and it shouldn't happen. But someone with more experience with WME might pitch in? Or is WME just another in the row of alpha state software MS releases as a finished product, with an even longer row of service packs needed to finish it?
/Mats -
how about this for a conspiricy theory that I thought of at lunch.
Most of your choices in WME are for capturing and creating WMV in rela time .... so they are set for capture.
So maybe (and again I am just theorizing here) when I do a file encode/convert .. it is not really converting the way TMPGENC is, but rather it is playing the actual file (internally) and then capturing/converting it in real time. Since I do know that when I am capturing a file coming in in real time I can lose frames etc based on type of CPU/memory and load.
Any chance I am right?
Any normal tool - or evne a proper setting to make WMV files?
My other computer runs o.k. after my browsers finally load...
By tcory in forum ComputerReplies: 3Last Post: 2nd Jan 2011, 21:28 -
No audio in MPC depending on the player exe file name
By mebs in forum Software PlayingReplies: 7Last Post: 27th Sep 2010, 02:06 -
CS4 media encoder file format for PS3
By hbecs02499 in forum Video ConversionReplies: 1Last Post: 11th Apr 2010, 06:10 -
Computer keeps trying to load some weird ntload.dll file
By jyeh74 in forum ComputerReplies: 40Last Post: 28th Dec 2009, 08:41 -
HELP! How to Streaming more than one wmv file in Windows Media Encoder
By smcalpine in forum Video Streaming DownloadingReplies: 4Last Post: 16th Jul 2008, 09:19
