I've tried in the past to copy to films at the same time, the same film not 2 different ones, I've had a few successes using disc juggler but more failures than anything else. Ive had no success using stomp. My set up is as follows. One of my dvd writers is on the same ide cable as the dvd rom and the other is on a ide cable with the hard drive. Would I have more success putting the both dvd writers on the same ide cable?![]()
Your problem is likely because they are on two different channels, yes. But it's possible that your limitation is in your chipset, or your hard disk.
What do you mean by limitation in my chipset, and how do I find the limitation, if that makes sense? my hard drive is 120 gig with 68 gig free. Wierd thing as well I just copied to cds using drag and drop and multi recorders and the first time it burnt perfectly, the 2nd time i did it using the same files it failed. By the way I used stomp because I cant find the setting for multiple recorders in nero.
Multi mkv files with subs into one disk to play to all bluray players
By fits79 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 27th Dec 2010, 06:27 -
DVD multi-region player question...
By mjl1297 in forum Newbie / General discussionsReplies: 8Last Post: 26th Apr 2010, 05:05 -
FLV - Multi Joiner, Multi Splitter, Multi Advert Removal
By oz_surfer in forum Newbie / General discussionsReplies: 0Last Post: 11th May 2009, 22:16 -
multi sessionon one disk
By bwsolich in forum Newbie / General discussionsReplies: 6Last Post: 6th Jan 2009, 03:13 -
Multi Disk DVD cases for 14 or more discs
By nerys in forum Newbie / General discussionsReplies: 0Last Post: 21st Jun 2008, 00:46
