I've been encoding my avi files with TMPGEnc and burning onto cd-r's. Some of the content I have consists of two avi files which would take 4
cd-r's to burn onto. Is there any way that I can encode both of those avi files with TMPGEnc then join them and burn it all onto one dvdr in the mpg format that would be playable on a standalone dvd player?
Anthony
Convert each clip to dvd with tmpgenc, use the wizard and you can set the output size to dvd or use a video bitrate calculator to calculate the video bitrate so it will fit on a dvd.
Then add each mpg clip when you author to a dvd, using for example tmpgenc dvd author.
And PLEASE use a subject that describes your topic. -
What Baldrick said, although I would use this guide.
Just remember that you need to input the total running time of all of the files combined into the bitrate calculator.If in doubt, Google it.
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 15:42 -
What is the different between TMPGEnc Authoring Works 4 & TMPGEnc 4.0 XPres
By c1steady in forum Newbie / General discussionsReplies: 0Last Post: 28th Apr 2010, 21:32 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
