I bought a Ben-Q dvd writer a few months back, only used it a few times, but on those times i had no problem.
Now when i go to use it to burn anything, my entire computer freezes...you can't even ctrl-alt-del.
This has happened using different software and different operations (burning a movie and data disk)
Any idea of what the problem is or how to resolve it, or do I just have to bring it back?
any help would be greatly appreciated.
thanks
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
If you have another drive on the same channel, remove it and try the drive attached as the only drive. Benq drives are known to be picky, my 822 only works set as the slave drive, and completely refuses to work in any external enclosure.
If this works, with the drive set to either master or slave, then maybe try reconnecting the other drive with the Benq set as slave. If the Benq is the only drive on the channel, try setting it to slave.
Video is blurry on computer but clear on HDTV, how can it happen?
By Bencuri in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 55Last Post: 26th May 2012, 11:48 -
what would you do if this happen to you?
By Webster in forum Off topicReplies: 8Last Post: 6th May 2011, 12:23 -
Why does this happen? Resolution problem.
By bananadude in forum EditingReplies: 8Last Post: 14th Jun 2008, 02:47 -
----jerky motion----when did that happen?----
By ozne64 in forum Video ConversionReplies: 6Last Post: 15th Jan 2008, 05:00 -
What will happen to analog cable after the digital switch???
By yoda313 in forum Off topicReplies: 5Last Post: 12th Jun 2007, 18:32
