At the moment, I've been using Sorenson Squeeze, I am very unimpressed with the results, maybe it's just in combination with my authoring tool or something bit it oversaturates most shots and the oversaturated colours 'hum' far too noticeably. So I tried authoring a DVD with the raw dv files (instead of squeeze's compressed to dvd files) and have the authoring program (Ulead DVD Workshop) compress the during the export, this gave a much better result that squeeze (the finished product on t.v looked much more like the original dv files), yet I can still see a little tiny bit of visible compression when I look hard or pause it.
So basically is there another specific program for compressing to DVD I could try? I used TMPGEnc for my video last year and was unimpressed with that too. Any suggestions?
Canopus Procoder Expresss
Mainconcept MPEG Encoder
CinemaCraft Encoder Basic -
DVD Workshop does a pretty good job.
Have you tried Womble MPEG Video Wizard? I've gotten superb DV-to-MPEG2 encodes using that.
Here are some more ideas on how to do it with freeware:
https://www.videohelp.com/guides.php?guideid=437#437
converting raw teltext data into other subtitle formats
By zorr00000 in forum SubtitleReplies: 8Last Post: 18th Jan 2012, 06:12 -
muxing raw h264 with raw g711 to mp4 continer
By niror in forum Newbie / General discussionsReplies: 5Last Post: 23rd Aug 2011, 12:25 -
HD Camcoder RAW file editing and converting.
By Bonie81 in forum Newbie / General discussionsReplies: 0Last Post: 1st Jul 2011, 13:30 -
Getting Avisynth to import raw avi without converting to RGB
By Asterra in forum Video ConversionReplies: 18Last Post: 22nd May 2011, 21:08 -
Converting a 60fps .MTS video to a 30fps raw .AVI?
By Anon1 in forum Newbie / General discussionsReplies: 1Last Post: 20th Jun 2010, 16:57
