I have a 3 hour TV program that will end up being about 2 1/2 hours.
The first VIDEO_TS folder will contain about 1hr40min and the second VIDEO_TS folder will contain about 50min.
Can I use DVD Shrink to combine into one VIDEO_TS?
If so, how?
Thanks.
So, in practice, you have 2 DVDs you want to author as one. Can be done with DVDShrink, Reauthor mode.
/Mats -
thanks for the quick replies
if I didn't want that slight pause, is there another way to do this using freeware? -
Then, you could:
Extract audio and video from all vobs in folder 1
Extract audio and video from all vobs in folder 2
(I'd use ReJig for this)
Author with TMPGEnc DVD Author (not freeware, I'm afraid...) with the A/V from the two folders as part of the same title. That way, it will play as one single movie.
/Mats -
Jimmalenko's guide uses freeware:
http://members.dodo.net.au/~jimmalenko/test.htm
It may give you more chapter markers than you want since it makes chapters based on cells. I've used it myself and it is very easy. Other than the extra chapters you might have...it is a great way to join two VIDEO_TS folders.
TMPGEnc DVD Author is a 30 day trial if I remember correctly. You may be able to remove the extra chapters with it. -
cool!
thanks much.
I have TMPGEnc DVD Author, so this looks like the way to go.
Split Avi to DVD creates Video_Ts folders w. garbled video intro. Help?
By wildgeese in forum ffmpegX general discussionReplies: 7Last Post: 10th May 2011, 17:56 -
Duplicate a DVD....can you simply copy Audio_TS folder and Video_TS folders
By True Colors in forum Authoring (DVD)Replies: 6Last Post: 29th Apr 2010, 14:37 -
AVI to DVD not outputting Video_TS or Audio_TS folders
By threesixes in forum ffmpegX general discussionReplies: 18Last Post: 30th Dec 2008, 01:23 -
How do I rip DVD to VIDEO_TS/AUDIO_TS folders?
By Crimea in forum Newbie / General discussionsReplies: 6Last Post: 18th Feb 2008, 11:34 -
how do install two folders video_ts in one dvd-r
By togood in forum DVD RippingReplies: 3Last Post: 13th Dec 2007, 05:58
