  1. I have a SVCD file
    found a guide to convert it to divx at the url:
    https://www.videohelp.com/avi2divx.htm
    it says...
    If your source is MPEG2(SVCD or DVD MPG files)
    or VOB you must use the Virtualdub-MPEG2.
    OK, got VirtualDub-MPEG2
    and followed the instructions...
    It's suggested to use fast recompress mode
    for video to avoid a useless double conversion
    between color spaces... RGB to YUV to RGB again
    BUT, it's also pointed out that if you are converting
    from SVCD you MUST use full processing mode
    because to resize video you have to use
    virtualdub filters ...and they work only adopting
    It is possible to make the conversion
    doing the resize thing AND
    deleting black bars due to letterboxing
    AND without losing the colors????????
    apart from that
    i always receive an error
    "Cannot start video compression
    The source image format is not acceptable
    (error code -2)"
    sorry if i'm probably asking
    stupid things
    I tried to avoid asking help
    reading a lot before asking
    but I'm really a newbie
    and I'm still trying to keep in memory
    all the infos gathered in these few hours
    thanks for any info/answer
    dee
    have you tried rip the svcd mpg using isobuster first? removing the svcd headers.
    https://www.videohelp.com/forum/userguides/141726.php#svcdbin
  3. about the link you gave me...
    isobuster asks for an image file...
    sure that i can put my SVCD/MPEG2 file
    into an ISO or similar image file...
    but it seems just an additional step
    and i don't know...
    but it seems useless too
    cause I can see the file...
    so i don't need something to repair
    a broken file i just need to convert
    to another format for other reasons
    probably i have to explain better
    what i'm trying to achieve
    I can see the mpeg files correctly with
    PowerDVD but my problems are:
    would like to have the file in a format that
    can be distributed with different subtitles files
    spanish, english, portoguese...
    I have the subtitles
    in .srt or .sub format
    I have the video file
    in SVCD/MPEG2 format
    BUT i cannot display subtitles and video
    together in powerdvd
    would like to merge files in one divx file
    every help is really appreciated
    thanks
    dee
    I linked to wrong https://www.videohelp.com/forum/userguides/141726.php#svcd
    You can also try virtualdubmod instead of virtualdub-mpeg2.
    but you can instead use Media Player Classic and play the svcd and add custom subtitles, just click on File->Load subtitle. Done!!!
