  1. Just some advice before i make any changes.
    I am using xp pro and have installed v2 no problem and have also sorted the DEP issue but having fun using avi files "mpg all work ok",
    I have saved 3 avi files in my projects folder but now when i try to open the saved file i get the Jit Debugging error box appear.
    I have read all the posts ref Jit error and chrissy wrote,
    " multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Windo ws XP Media Center Edition" /fastdetect /NoExecute=OptIn "
    The NoExecute needs to be changed to EXECUTE but how do i edit it.
    I have gone into msconfig then boot ini but i cant see how to change it.
    If this will sort out my Jit error please can someone tell me how to edit the section in question.
    Thanks.
  2. Just open the boot.ini file with notepad.
    My boot.ini just has the FASTDETECT/EXECUTE
  3. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    If you have sorted DEP, what JIT error are you having?
  4. An unhandled exception has occured in your application.If you click continue,the application will ignore this error and attempt to continue "DID NOT WORK".
    If you click Quit,the application will be shut down immediately.
    THEN IN THE BOX IT WHAT IS SHOWN BELOW.
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.NullReferenceException: Object reference not set to an instance of an object.
    at System.Windows.Forms.ListView.InsertItem(Int32 displayIndex, ListViewItem item)
    at System.Windows.Forms.ListViewItemCollection.Add(Li stViewItem value)
    at SVCD2DVD.210ff09a2516b1a7.c456b78441ff1c49()
    at SVCD2DVD.210ff09a2516b1a7.6341f549d2d05feb(Object e0292b9ed559da7d, EventArgs fbf34718e704c6bc)
    at DevComponents.DotNetBar.DotNetBarManager.92(BaseIt em 2IP)
    at DevComponents.DotNetBar.BaseItem.RaiseClick()
    at DevComponents.DotNetBar.BaseItem.InternalMouseUp(M ouseEventArgs objArg)
    at DevComponents.DotNetBar.PopupItem.InternalMouseUp( MouseEventArgs objArg)
    at DevComponents.DotNetBar.ButtonItem.InternalMouseUp (MouseEventArgs objArg)
    at DevComponents.DotNetBar.GenericItemContainer.Inter nalMouseUp(MouseEventArgs objArg)
    at DevComponents.DotNetBar.Bar.OnMouseUp(MouseEventAr gs e)
    at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at DevComponents.DotNetBar.Bar.WndProc(Message& m)
    at System.Windows.Forms.ControlNativeWindow.OnMessage (Message& m)
    at System.Windows.Forms.ControlNativeWindow.WndProc(M essage& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Loaded Assemblies **************
    mscorlib
    Assembly Version: 1.0.5000.0
    Win32 Version: 1.1.4322.2032
    CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
    SVCD2DVD
    Assembly Version: 2.0.1781.28310
    Win32 Version: 2.0.1781.28310
    CodeBase: file:///C:/Program%20Files/Badgersoft/SVCD2DVD%202%20BETA/SVCD2DVD.exe
    CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
    System
    CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
    System.Drawing
    CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
    Assembly Version: 4.5.0.0
    Win32 Version: 4.5.0.1
    CodeBase: file:///C:/Program%20Files/Badgersoft/SVCD2DVD%202%20BETA/DevComponents.DotNetBar.DLL
    AxInterop.CodeLock
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Program%20Files/Badgersoft/SVCD2DVD%202%20BETA/AxInterop.CodeLock.DLL
    System.Xml
    CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
    Accessibility
    Win32 Version: 1.1.4322.573
    CodeBase: file:///c:/windows/assembly/gac/accessibility/1.0.5000.0__b03f5f7f11d50a3a/accessibility.dll
    Interop.CodeLock
    CodeBase: file:///C:/Program%20Files/Badgersoft/SVCD2DVD%202%20BETA/Interop.CodeLock.DLL
    Interop.QuartzTypeLib
    CodeBase: file:///C:/Program%20Files/Badgersoft/SVCD2DVD%202%20BETA/Interop.QuartzTypeLib.DLL
    System.Design
    CodeBase: file:///c:/windows/assembly/gac/system.design/1.0.5000.0__b03f5f7f11d50a3a/system.design.dll
    SVCD2DVDLib
    Assembly Version: 1.0.1778.36068
    Win32 Version:
    CodeBase: file:///C:/Program%20Files/Badgersoft/SVCD2DVD%202%20BETA/SVCD2DVDLib.DLL
    Microsoft.VisualC
    Assembly Version: 7.0.5000.0
    Win32 Version: 7.10.3052.4
    CodeBase: file:///c:/windows/assembly/gac/microsoft.visualc/7.0.5000.0__b03f5f7f11d50a3a/microsoft.visualc.dll
    ************** JIT Debugging **************
    To enable just in time (JIT) debugging, the config file for this
    application or machine (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
    <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the machine
    rather than being handled by this dialog.
  5. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    ok. i need you to email me the .s2d file please.
  6. E-mail sent
    I will also pm you.
  7. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    ok. Well spotted! I know what the issue is and it will be fixed in the next build. Basically reloading a SVCD2DVD project which contains AVI assets is broken... For now you will have to start a new project to process them.
    It will be fixed in the next beta.
