I can't seem to use mencoder in ffmpegX anymore. I thought the new version (0.0.9q) would fix it. However, when trying to use 'auto-crop' I get the crash report below. Any idea on how it occurred? It could easy be some form of conflict with another piece of software. Any help? major?
Thank you in advance,
Dale
Code:Date/Time: 2004-11-23 13:04:31 +0000 OS Version: 10.3.6 (Build 7R28) Report Version: 2 Command: mencoder Path: /Library/Application Support/ffmpegX/mencoder Version: ??? (???) PID: 1360 Thread: 0 Exception: EXC_BAD_INSTRUCTION (0x0002) Code[0]: 0x00000002 Code[1]: 0x0016e098 Thread 0 Crashed: 0 mencoder 0x0016e098 0x1000 + 0x16d098 1 mencoder 0x00165f40 0x1000 + 0x164f40 2 mencoder 0x0007d474 0x1000 + 0x7c474 3 mencoder 0x00072e40 0x1000 + 0x71e40 4 mencoder 0x00005ea4 0x1000 + 0x4ea4 5 mencoder 0x00002bf8 0x1000 + 0x1bf8 6 dyld 0x8fe1a558 _dyld_start + 0x64 PPC Thread State: srr0: 0x0016e098 srr1: 0x0008f030 vrsave: 0x00000000 cr: 0x28488280 xer: 0x00000000 lr: 0x00166b2c ctr: 0x001665ec r0: 0x00000000 r1: 0xbfffe480 r2: 0x32315659 r3: 0x01819600 r4: 0x00000100 r5: 0x01705000 r6: 0x000002d0 r7: 0x0002d000 r8: 0x01811000 r9: 0x01808c00 r10: 0x00000010 r11: 0x52470000 r12: 0x010c9094 r13: 0x00000010 r14: 0x00000100 r15: 0x0130e290 r16: 0x00000000 r17: 0xbfffe650 r18: 0x00000000 r19: 0x00000000 r20: 0x00000000 r21: 0x0000000f r22: 0x00000001 r23: 0x00000000 r24: 0x0000000f r25: 0x010c9000 r26: 0x00000010 r27: 0xffffffff r28: 0x0130c734 r29: 0x00000010 r30: 0x00000000 r31: 0x00166604 Binary Images Description: 0x1000 - 0x5aafff mencoder /Library/Application Support/ffmpegX/mencoder 0x8fe00000 - 0x8fe4ffff dyld /usr/lib/dyld 0x90000000 - 0x90122fff libSystem.B.dylib /usr/lib/libSystem.B.dylib 0x90190000 - 0x9023dfff com.apple.CoreFoundation 6.3.5 (299.32) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x90280000 - 0x904f9fff com.apple.CoreServices.CarbonCore 10.3.6 (10.3.5) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore 0x90570000 - 0x905dffff com.apple.framework.IOKit 1.3.6 (???) /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit 0x90610000 - 0x9069afff com.apple.CoreServices.OSServices 3.0.1 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices 0x90700000 - 0x90700fff com.apple.CoreServices 10.3 (???) /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices 0x90720000 - 0x90787fff com.apple.audio.CoreAudio 2.1.2 /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio 0x907f0000 - 0x907f9fff com.apple.DiskArbitration 2.0.4 /System/Library/PrivateFrameworks/DiskArbitration.framework/Versions/A/DiskArbitration 0x90810000 - 0x90810fff com.apple.ApplicationServices 1.0 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices 0x90910000 - 0x90983fff com.apple.DesktopServices 1.2.2 /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv 0x90d00000 - 0x90d1bfff com.apple.SystemConfiguration 1.7.1 (???) /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration 0x90d40000 - 0x90d40fff com.apple.Carbon 10.3 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon 0x910b0000 - 0x91101fff com.apple.bom 1.2.5 (63.2) /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom 0x912a0000 - 0x912bdfff com.apple.audio.SoundManager 3.8 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound 0x912e0000 - 0x912f7fff com.apple.LangAnalysis 1.5.4 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis 0x91320000 - 0x913defff ColorSync /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync 0x91460000 - 0x91473fff com.apple.speech.synthesis.framework 3.2 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis 0x914a0000 - 0x91509fff com.apple.htmlrendering 1.1.2 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering 0x91560000 - 0x91619fff com.apple.QD 3.4.65 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD 0x91670000 - 0x916a8fff com.apple.AE 1.4 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE 0x916e0000 - 0x91773fff com.apple.print.framework.PrintCore 3.3 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore 0x917e0000 - 0x917f0fff com.apple.speech.recognition.framework 3.3 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition 0x91810000 - 0x9182afff com.apple.openscripting 1.2.1 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting 0x91850000 - 0x91860fff com.apple.ImageCapture 2.1.5 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture 0x91890000 - 0x9189cfff com.apple.help 1.0.1 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help 0x918c0000 - 0x918cdfff com.apple.CommonPanels 1.2.1 (1.0) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels 0x918f0000 - 0x9193efff com.apple.print.framework.Print 3.3 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print 0x91990000 - 0x9199bfff com.apple.securityhi 1.2 (90) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI 0x919c0000 - 0x91a33fff com.apple.NavigationServices 3.3.2 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices 0x91ab0000 - 0x91ac4fff libCGATS.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGATS.A.dylib 0x91ae0000 - 0x91aebfff libCSync.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib 0x91b10000 - 0x91b2afff libPDFRIP.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libPDFRIP.A.dylib 0x91b50000 - 0x91b5ffff libPSRIP.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libPSRIP.A.dylib 0x91b80000 - 0x91b93fff libRIP.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib 0x91bb0000 - 0x91d45fff com.apple.QuickTime 6.5.2 /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime 0x92070000 - 0x92096fff com.apple.FindByContent 1.4 (1.2) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/FindByContent.framework/Versions/A/FindByContent 0x920c0000 - 0x922a7fff com.apple.security 2.4 (177) /System/Library/Frameworks/Security.framework/Versions/A/Security 0x92430000 - 0x92468fff com.apple.LaunchServices 10.3.5 (98.4) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices 0x92740000 - 0x92777fff com.apple.CFNetwork 1.2.1 (7) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork 0x927d0000 - 0x92b54fff com.apple.HIToolbox 1.3.4 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x92d30000 - 0x92d80fff com.apple.HIServices 1.4.1 (0.0.1d1) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices 0x935d0000 - 0x938a8fff com.apple.CoreGraphics 1.203.26 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics 0x939a0000 - 0x939b4fff libcups.2.dylib /usr/lib/libcups.2.dylib 0x939d0000 - 0x939d4fff libmathCommon.A.dylib /usr/lib/system/libmathCommon.A.dylib 0x94060000 - 0x94078fff com.apple.WebServices 1.1.1 (1.1.0) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/WebServicesCore.framework/Versions/A/WebServicesCore 0x94120000 - 0x9414bfff libncurses.5.dylib /usr/lib/libncurses.5.dylib 0x945b0000 - 0x945b9fff libz.1.dylib /usr/lib/libz.1.dylib 0x94610000 - 0x9462afff libresolv.9.dylib /usr/lib/libresolv.9.dylib 0x94650000 - 0x946affff com.apple.SearchKit 1.0.2 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit 0x94b20000 - 0x94badfff com.apple.ink.framework 101.1.3 (55.10) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink 0x968d0000 - 0x969b2fff libicucore.A.dylib /usr/lib/libicucore.A.dylib 0x96a20000 - 0x96ae2fff libcrypto.0.9.7.dylib /usr/lib/libcrypto.0.9.7.dylib 0x96b40000 - 0x96b6efff libssl.0.9.7.dylib /usr/lib/libssl.0.9.7.dylib 0x96bf0000 - 0x96c7ffff ATS /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS 0x96cb0000 - 0x96d9efff libiconv.2.dylib /usr/lib/libiconv.2.dylib 0x97510000 - 0x97518fff libbsm.dylib /usr/lib/libbsm.dylib
Results 1 to 1 of 1
Mencoder and watermarks
By FlyerUA in forum Video ConversionReplies: 0Last Post: 6th Feb 2012, 16:50 -
TREM in Mencoder, what is it?
By RogerTango in forum Video ConversionReplies: 2Last Post: 24th Sep 2011, 09:49 -
AAC in MENCODER
By banon in forum LinuxReplies: 2Last Post: 3rd Oct 2008, 07:27 -
Simple DivX: Crashes with Mencoder Error Every Time
By CobraPilot in forum DVD RippingReplies: 5Last Post: 10th Jul 2008, 19:47 -
Mencoder
By juanpedro01 in forum LinuxReplies: 2Last Post: 27th May 2007, 12:58
