I think the title is self explanatory..![]()
I have a eVGA GeForce FX 5200 Video Card 128mb
I have tried using somthing called NHP but i really cant see a visual differance. (NHP enables a overclocking thing in Nvidia properties)
Thanks in advance.![]()
Results 1 to 12 of 12
If that app allows for changing of memory and clock speed, basically what you do is tweak each of them and raise them up, one at a time - slowly - until you notice issues with the vid card. Then scale back a bit, and that's as fast as it's capable of.
What you want to do while seeing how far you can raise it is run something like 3dmark in a loop. It will stress the card nicely. Look for freezing or artifacts and things like that. It will also give you a numerical identifier of your computer's overall performance. CPU and ram will come into play, but since they are not changing you will be able to clearly see the increase in performance of your card because of the overclocking. -
http://www.ocfaq.com/article.php/overclocking/33
Let us know how you get on!
Also, ever considered overclocking your CPU?
Cobra -
i would love to OC my card, but it already runs too hot as it is
I also want to overclock my video card and CPU, but I know absolutely nothing about it. I have an ATI Radenon 9800. Do you need an extra fan just to overclock the card?
Originally Posted by viperx116
You can normally get something more out of it with stock cooling. That's what I'm doing just now. Do a Google search and find out about it, it's very common. I think RivaTuner would suit you best, since CoolBits is nVidia only.
Also, please try not to threadjack. This is only a semi-threadjack, I know.
Cobra -
Just wondering, is overclocking bad for your video card or processor?
It can be, depending on how far you take it. If it is a mild overclock, it shouldn't make much difference to the life of the component. If you are running it right to the very limit (as I do) then your components will be prone to failing early. Would you drive your car to the redline every day, and expect it to last?
Most overclocking is very safe, provided you are sensible about it. -
Ok sorta hijacking my own topic but how would i overclock my AMD Antholon 1Ghz?
Read my signature.
Using an Onboard video card with a PCI video card
By Nastydave in forum Media Center PC / MediaCentersReplies: 3Last Post: 6th Apr 2012, 02:37 -
Overclocking, memory problems??
By HotDamn! in forum ComputerReplies: 26Last Post: 29th Apr 2010, 12:05 -
Does overclocking mess up on-board video ?
By SingSing in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2009, 23:39 -
Looking for new driver for video card- MEDION (7134) WDM Video Capture card
By 2prfm.com in forum Capturing and VCRReplies: 3Last Post: 15th Sep 2008, 02:48 -
overclocking a 6750...& sundrys
By RabidDog in forum ComputerReplies: 4Last Post: 6th Apr 2008, 08:53
