I have an svcd file which has out of sync audio, video about 4 s ahead. Trying to rectify this, i used a few different methods, including those listed on this site in the guides. De-multiplexing files in tmpgenc is no problem, but when trying to Multiplex the trimmed sound file and original video feed, i just get one long black screen with no sound as it's output. Then trying to re-encode the video in tmpgenc, it refuses to load the mpeg, saying "cannot open or unssuported". When trying to use virtualdub (modded and regular version) i get an pack synchronization error and it will not load. By using extended options and selecting "allow partial streams" it allowed me without a warning, but with no video showing, and crashed and soon as i pushed the frameserv button. G-spot recognizes the file and says renders correctly with something called "ligos", but gives "n.a." for video and audio codec of file. This file works perfectly with the exception of the audio sync, can somebody please help me make sense of it, because i've been rippin my hair out for the last 3 hours.
Originally Posted by nick_man989
Tmpgenc has problems opening mpeg-2 files (as you have seen). Things to try. Install PowerDVD (the demo will do) and TmpGenc will use the mpeg-2 code this installs to open the mpeg. If it still fails try raising the direct show priority under environmental settings.
If this still doesn't work, you can frameserv it using DVD2Avi. Just loead your mpeg and select save project. This will creat a large audio file and a much smaller projuect file (I forget the extension at the moment, something like .d2v) Anyway, open this file as the video source in TmpGenc and it should be happy.
Authoring programs
By countmonster in forum Authoring (DVD)Replies: 2Last Post: 27th Dec 2011, 07:59 -
Sony Vegas 9.0 Has no audio on rendered file
By cowombat in forum Newbie / General discussionsReplies: 3Last Post: 25th Oct 2009, 08:02 -
Vegas AVI 2gig rendered file size limit
By Gargalash in forum EditingReplies: 2Last Post: 17th Nov 2008, 09:12 -
Authoring programs for Mac
By turbochargedRS in forum MacReplies: 8Last Post: 12th Mar 2008, 23:42 -
Sony DVD-Architect won't load markers in mpeg file rendered in Vegas
By mltwitz in forum Authoring (DVD)Replies: 1Last Post: 25th Jan 2008, 10:01
