i just got a new lap top and it has a program on it called sonic mydvd and when i try to burn a dvd i can only fit 3 avi files of max 65 megs on it, that doesnt seem right. anyways wondering if everyone knew of any compressing programs or a better burning program that will do this better.
Andrew
GO NUCKS!
What kind of DVD are you trying to burn? Data backup? DVD Video? What? Sonic isn't what you want for data and AVI is not in the DVD Video specification and must be converted. Your files are likely highly compressed Divx/Xvid/MPEG4 encoded AVIs of one flavor or another and they balloon in size when decompressed to MPEG2, especially if your Sonic program is using PCM audio by default as the older versions did.
Sonic MyDVD serves a useful purpose for noobs just starting out, but you'll soon be itching to take the training wheels off and try out better software once you start to understand this stuff.
Ton of guides and info to the left there. Make use of the search feature, also. It is your best friend here. Trust me on this."There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
ya i have a bunch of movies that i want to put on dvd so i can watch in on tv, anyways ya can u recomend a good guide or what i should search for?
basically want to fit as many episodes on one dvd at fairly good quality, and wondering the best way to do so.
Thanks for your helpGO NUCKS! -
How much you can fit on a DVDr is determined by runtime and bitrate of your videos. TMPGEnc is a popular program for converting the type of files you have. It comes with a bunch of pre-configured templates you can use to make things easier for you while you're learning. You'll have to convert them and then author them to a title set, then burn them to DVDr.
These are the specs you're shooting for to make your files into DVD compliant streams. This is found all the way at the top to the left, clicking on DVD under the "What is" heading for future reference.
Use the search to find guides on converting."There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
Burning AVI Files in Toast 7
By Luckyword in forum MacReplies: 9Last Post: 16th Jul 2010, 12:05 -
Converting then burning AVI files
By Tbag in forum Authoring (DVD)Replies: 5Last Post: 7th Jun 2008, 16:24 -
large file size when importing small video clips into Sonic MyDVD
By artistream in forum Newbie / General discussionsReplies: 2Last Post: 1st Nov 2007, 19:48 -
Problem Burning Some AVI Files
By Averc in forum Newbie / General discussionsReplies: 9Last Post: 8th Oct 2007, 10:33 -
Burning .avi files
By pilgrim02 in forum MacReplies: 13Last Post: 31st Jul 2007, 11:52
