hello this is my 1st post and any feedback would be welcomed.
basicly i have a avi file that plays perfect.but when i encode it 2 dvd it comes out out of sync.i used a few diferent programs to encode (dvd santa and ulead dvd movie facorty 3) but the same results.
i even used tmpeg to change it 2 a mpg and th same results.
what can i do?
thanks for any feed bcak.
How "out of sync"?
- Off from start, staying the same thruout? Then you have to compensate when authoring or multiplexing, or cut some / add some silence at the beginning of the audio.
OK to start with, getting gradually out of sync as the movie plays? (Then it's probably due to that your source and your dest doesn't have the same frame rate)
OK to start with, then suddenly goes out of sync? Then the source AVI has bad/undecodable frames: See guide on how to remove bad frames, or get an error free source.
/Mats - Off from start, staying the same thruout? Then you have to compensate when authoring or multiplexing, or cut some / add some silence at the beginning of the audio.
it starts out of sync when its been coverted into dvd.the sound is maybe 5 or 6 seconds faster tahn the audio.
should i use tmpeg 2 make a sound file and a picture file, then add the silence in a music program.
thank you very much foe replying. i will try adding silence and let u know the results soon.
thanks -
Yes, that's the general idea. But if you're encoding with tmpgenc, I think there's a setting for "audio delay" somewhere that you can use to compensate.should i use tmpeg 2 make a sound file and a picture file, then add the silence in a music program.
If not, you separate the audio from the AVI (use VirtualDub for this step), edit the audio (GoldWave), then use original AVI as video source, edited audio as audio source.
/Mats
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
Looking for a new 1TB internal drive. Seagate too many issuses now?
By Denvers Dawgs in forum ComputerReplies: 9Last Post: 12th Jun 2010, 07:37 -
MPG with A/V sync to AVI with horrible A/V sync?
By RedPenguin in forum Video ConversionReplies: 92Last Post: 23rd Aug 2009, 17:17 -
sync issuses?
By just in forum Newbie / General discussionsReplies: 3Last Post: 5th Nov 2008, 22:38 -
DVD encoding issuses w/ progressive fames plays back as interlaced. SOLVED!
By ty1er in forum DVD RippingReplies: 1Last Post: 19th Aug 2008, 09:34
