VBA
  1. I am trying to switch between two different instances of excel (they show up as seperate spreadsheets on the taskbar) but the code I have been given to try doesn't work -
    Dim OtherSheet As Object ' Variable to hold reference
    On Error Resume Next
    Set OtherSheet = GetObject(, "Excel.Application")
    Set OtherSheet = GetObject("U:\Decision Support\VB Testing\File swap2.xls").Activate ' <<<< FULL FILE PATH HERE
    OtherSheet.Application.Visible = True
    Set OtherSheet = Nothing ' Release reference to the application and spreadsheet
    It just throws up an error 424 Object Required at the second get object line. Can anyone point me in the right direction ?
    Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard.
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    It seems a littel odd to me, even if I'm no VBA guru:
    First you create an excel application and assign it to othersheet
    Then you try to assign the result from .activate to othersheet
    Doesn't make sense.
    Disregarding first line, I'd try
    OtherSheet.Activate
    ...and the rest.
    The first line is wasted, as the second immediately changes the first assignment.
    /Mats
  3. Member tekkieman's Avatar
    Mar 2004
    Over the hill
    The problem is that no object has been created. GetObject is used when you already have an existing object. Instead of the first line using GetObject, set it to CreateObject. Then the object will exist when the second line is executed. Another way would be to trap the error 429. (Psuedo code) If 429 then Set blah - CreateObject(....
    This way, if the code gets executed several times in the app, it will work if the object already exists, or create it if it doesn't.
    EDIT: Sorry, here's a better example.
        Dim olApp As Object
        Set olApp = GetObject(, "Excel.Application")
        If Err.Number = 429 Then
            Set olApp = CreateObject("Excel.application")
        End If
  4. Cheers guys !
  5. Member tekkieman's Avatar
    Mar 2004
    Over the hill
    Anytime. Did you get it squared away?
  6. Originally Posted by tekkieman
    Kind of - I went away and looked at a different way of doing things and it now works.
