Results 1 to 14 of 14
    Nov 2004
    Canada
    I have this OEM Nero CD that came with my NEC drive, it has all the Nero 6 functionalities and all the features (Nero Startsmart)... but I JUST HATE the stupid interface of Express... I remember on the 5.5 I was able to change from Express to normal Nero Burning ROM full-version with a tweak... how can I do that on Nero Express 6, if at all?
    Thnx a lot!
    Apr 2003
    Maryland
    Diferent Serial # I believe.
    No DVD can withstand the power of DVDShrink along with AnyDVD!
  3. Member CaZeek's Avatar
    Aug 2003
    NJ, DC, or Baltimore
    There should be a button on the bottom of the Nero Express window that says "Nero". If you click it, you'll get out of express mode. I'm not sure if you're looking at the same version as the Nero 6 I've run, but if so, that's how you do it.
  4. Member northcat_8's Avatar
    Mar 2003
    Chit, IDK I'm following you
    The nero that came with your burner is the OEM version. You have to purchase the full version.
    I crossed that bridge a few years ago when I bought my burner.
  5. what a pain in the ass that is.
    i hate how Nero did that. it's so confusing.
    Nov 2004
    Canada
    I beleive in 5.5, if you have "Nero" you could have switched back and forth between Nero and Nero Express.
    If your Burner came with Nero Express, there was no option to goto Nero, HOWEVER, there was a tweak (dont remember what), that would have enable you to make it Nero and I did that when I got my last Nero Express (but dont remember now, as it was like 2 years ago).
    So, was wondering if there's a tweak like that for Nero 6 or not?!
  7. There is a little flame thing, looks like a baby basinet on fire, clicking on it toggles between the two modes. I have purchased the 6 version over the OEM but I think the former had the two different modes. Try programs, nero, nero burning rom. The fire thing on top will change it to Express. The fire thing on the bottom will change it back.
    Ayr, Scotland
    In Nero Express the Flame Icon -Nero is bottom left. Single click takes you to Nero Burning Rom
    For the reverse there is a Flame Icon in the Toolbar (under Database) - gives tooltip "switches to Nero Express". Or open Help > Use Nero Express. You're just another click away.
    PS I have Nero 6 SE with d/l upgrades to 6.6
    Nov 2004
    Canada
    When I click on the flame button called "Nero" it opens up a new window and says "Visit Nero.com to find out why Nero is the best...."
    I dont see any other option on the programs to get the damn Nero Burning Rom...
    Even their help says to click on that button to switch to Nero Burning Rom... but it doesn't do it!
  10. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I think so too.
    If in doubt, Google it.
    Nov 2004
    Canada
    I think so too.
    Yes, it's the serial number. I removed the serial number in SmartStart, then it showed me the Nero Burning ROM icon... I chose it, it asked for serial number, I entered it, it accepted it and I went in and actually burned a couple of DVDs... BUT THEN, after I closed it, it went back to the damn express! I did the same thing and got in the Burning ROM but after closing it, it will go back to the damn freaking express... I HATE EXPRESS
  12. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I think the last time I had issues with serial numbers for Nero, I removed the serial number as you did in smartstart, then rebooted, then go into nero, enter your serial number, then reboot again. If I didn't do the reboots inbetween it did what yours is doing. Just a thought
    Nov 2004
    Canada
    Ok, will try that then. Thnx
    Nov 2004
    Canada
    restart didnt's work either! I think my OEM serial# doesn't include Burning ROM which is QUITE STUPID... it's like it express does everything that Nero does but for DUMB PEOPLE and I guess they assume OEM users are DUMB people
