  1. Hi Guys,
    Can someone please help me with this. I have NEro 5.5.4 & have the OEM key with the software.What i s happening is when i convert an .avi file to .mpg using TMPGEnc, NERO does not let me make a VCD. The Burn CD button is not highlighted. I have an Iomega External CD writer.I have tried Highlighting the File, The CD but still no luck
    I used to use EZ CD Creator 5 platinum & it works fine but EZ CD does not let me create SVCD's so i need to switch to NERO. So please if some one can help me.I would appreciate.
  2. pats:
    If Nero doesn't recognize your CD burner at all (hence "Burn" being greyed out, it may be because Roxio EZCD creator was not fully uninstalled - meaning that even though the program uninstalled, there is still a registry entry that lists the Roxio cd burner interface (i think its in the lower limits as "pxhelper" - if you do a search, I think you'll find the registry edits required)
    I had a problem just trying to get Nero to recognize my drives after uninstalling EZCD. Then I found the fix, and all is well ! !
    Hope this helps.
  3. Hi TAllee,
    Thanks for the help, but it does not solve my problem. I still cannot burn VCD`s with NERO. I formatted the entire system Then installed only NERO but still no luck.
    anyways..thanks
  4. There is a way for Nero to detect 'unknown' CD burner.
    Check this page - http://www.nero.com/en/Autodet.htm
