I read in this site the DVD player hack copied below. Does anyone know where to get those components mentioned?
Other hack posted by manija, November 19 2004:
How to Modify the Power Supply of PHILIPS DVP 642 DVD player to 220 V ?
To convert to Autovoltage (100V to 240V) Just replace the following components from the power supply board:
Original Part_____Replace by this
C304:_68uF_250V_by_33uF_450V
C301:_.1uF_250V_by_.1uF_650V
VTR1:_(145V_10mm_Varistor)_by_(300V_10mm_Varistor) . (you can also remove this component)
The design uses the Fairchild KA5H02659R IC to drive the power supply, and there's no further changes needed to work as Autovoltage 100V to 240V
At this time there are at least a dozen of this DVD players working fine with this modification.
If you feel scare, try using a serial Lamp 25W 220V, if something goes wrong, the lamp will be On all the time, it's normal if on the first 2 seconds.
Enjoy it!
Manija
