I want to upgrade my pc since I am getting into video editing a little more here.
Couple questions.
Don't know which ram I will need yet as I have not decided on a processor but I will use this for an example.
1 gig PC 4400 DDR ram $247
1 gig PC 3500 DDR ram $146
Prices from pricewatch.com
Will I notice that much of a difference between these to merit the $101 price difference?
Will I notice any difference if I buy a 15000rpm hard drive as opposed to a 7500 rpm hard drive.
What processor do you reccommend....AthlonXP, Athlon 64, Pentium 4??
I am probably not looking to spend more than $400 for the motherboard/chip combo....unless I can get a really significant difference for another $100 or so.
Basically I will be editing video from a DVD camcorder.
Answers to these questions or any other advice will be greatly appreciated.
Thank You,
Andy
I'd recommend a Pentium 4 3.0c, 800fsb which is a northwood chip. The Prescott chips have major heat problems.What processor do you reccommend....AthlonXP, Athlon 64, Pentium 4??
http://www.newegg.com/app/ViewProductDesc.asp?description=19-116-156&depa=1
Crucial Tech memory pc3200, (2) 512 sticks
http://www.newegg.com/app/ViewProductDesc.asp?description=20-146-541&depa=1 -
15k drives are going to cost you $$$ so forget those if you're on a budget.
FB-DIMM are the real cause of global warming
Which editing-software for my needs and hardware-specs?
By spinningrom in forum EditingReplies: 11Last Post: 30th Aug 2011, 16:23 -
Editing Video questions
By grenparas in forum EditingReplies: 7Last Post: 11th Mar 2011, 23:55 -
Questions about video encoding/editing
By Shikikazu in forum Newbie / General discussionsReplies: 4Last Post: 23rd Oct 2010, 21:12 -
some questions regaurding hardware video editors?
By kopmjj in forum RestorationReplies: 4Last Post: 3rd Apr 2010, 23:26 -
MAC Video Editing Questions
By faramith in forum MacReplies: 7Last Post: 1st Jul 2007, 11:34
