I have a pioneer 108 and I have been using Prodisc 8x for awhile. I don't know if it's the media or the burner, but about halfway through a disc (burning) the thing stops writing and after a few seconds begins writing again. This is at 8x and 12x. I want to say its a media problem, but I can't say for sure...Is it possible that the burner is going kaput?
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Boy do I love my avatar!
I know the drive changes from 6x to 8x about 4 minutes in it goes down to 0 then it jumps up to 8x. I haven't burned faster than the 8x yet. Out of 200 I have burned the past few weeks, I have only had one bad burn. Hope this helps.
Are you making coasters? Or just curious about the spped changes? -
just curious about the stop in writing for a moment. I hadn't noticed it before. Plus when the drive starts back up you can hear it wind up a second or two. That is something that I can't remember noticing either.
EDIT: Burning with DvdDecrpyter using .img. I haven't done this with Vid ts folder yet. Will try that next.Boy do I love my avatar! -
90 % of my Burns are done with DVDDecrypter and it always does it. Unless you burn at 4x. Then it never drops below the 4x. Using Recordnow you can still hear it shift gears at about the halfway point.
ah ok. i have been burning for about a year. This is my second burner (the first was 4x) and I have had it for about 3 or 4 months. I just can't believe I never noticed it b4! Silly
It's just shifting from 4x to 6x to 8x.
If God had intended us not to masturbate he would've made our arms shorter.
George Carlin
Is it easier on the burner to use R or RW media?
By PuzZLeR in forum DVD & Blu-ray RecordersReplies: 25Last Post: 28th Nov 2008, 12:40 -
LightScribe Media with Sony Burner.
By dragonsbb16 in forum MediaReplies: 11Last Post: 14th Dec 2007, 21:44 -
windows media player loses burner
By dfbrown in forum ComputerReplies: 4Last Post: 10th Jul 2007, 13:20 -
I need a 100% reliable burner and media.
By sneaux in forum MediaReplies: 36Last Post: 17th Jun 2007, 18:00 -
After a new burner and media.
By SE14man in forum Newbie / General discussionsReplies: 3Last Post: 31st May 2007, 11:03
