  1. Could you guys suggest what DVD Burning software I should get to use in conjunction with the new DVD Burner I am getting. I would like to be able to burn movies onto my "HD">>>>
    I think there is a nero program, just not sure of the exact program and I think DVD Shrink or something.
    Could you please fill me in?
    Thanks so much,
    Jim
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I use Nero and DVDDecrypter. Take a look at the burning subsection in the tools section for a whole list of different burning tools.
    If in doubt, Google it.
  3. DVD Shrink or something.
    DVD Shrink works great. The thing is is that alot of commercial dvds are over 4.7 GB, the size of dvd+/-rs. So you need to decode them and shrink them down to back them up. DVD Shrink does all of this for free.
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    as far as burning software goes though, DVDShrink is not burning software !!! It uses Nero or DVDDecrypter to burn.
  5. as far as burning software goes though, DVDShrink is not burning software !!! It uses Nero or DVDDecrypter to burn.
    Right... all you have to do is make a new data dvd in your favorite burning software and drop the outputted VIDEO_TS and AUDIO_TS folders from DVD Shrink onto it and your done!
  6. Which Nero program do you guys use and where can I get it. I do have a nero program on my computer, I think it is Nero Express. Will it do the job?
  7. Which Nero program do you guys use and where can I get it. I do have a nero program on my computer, I think it is Nero Express. Will it do the job?
    Yep, that will work fine. There are also alot of free burning apps in the tools section.
