  1. hi ppl,
    i encountered the following problem lately. downloaded this movie file.
    There is 2 file actually. one was a "bin" file e other a "cue" file.
    so next i just use "win iso" to extact the "bin" file...
    CDI, EXT, MPEGAV, SEGMENT, VCD folder thus created.
    I then went on to MPEGAV to open the movie.... zbc.DAT
    It was played with Media Classic Player. (klmcodec), e audio was fine, but the pic was fully distorted with alot of squeaking noise.
    May i know why issit so, cos of codec ? or file corrupted. Player was tested with other VCD DAT file. it work just fine. also this is not the first time i encounter such problem from movie downloaded from the net...
    PLS ADvise...
  2. some query...how shld we go abt for the CUE file ? ignore ?
    Also do we need special codec to play SVCD file ?
    Thks
  3. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Mpeg2 codec required, comes when you install powerdvd, windvd etc.
  4. I have powerDVD, result is e same...
    May 2004
    I have coworkers that buy disks of old music videos from S Amer. They had the identical file format. Odds are the .dat file is the old Intel Video codec "indeo". If you make a copy of the dat file and rename it as a .mpg you should be able to recode it and burn a dvd which will play on a tabletop. Use gspot to check the codec. Indeo is now owned by Ligos, so that will probably be the name gspot lists for the codec.
