I just got my unit today and I was wondering if there is a way to tell what the firmware version is before upgrading to the new firmware.
Is the original firmware available in case the new one makes it worse? I only see the firmware dated 11/15 on the iLo site.
Using your remote make sure your target is HDD (Hard Drive) Press Setup button and there will be a number at the bottom of the screen.
Mine is
SN:4E05-140-0191-G2B9
The third number from the left is your firmware number. If it's the original firmware it will have "0146".
Hope this helps!
Installed latest Ripbot264, says Java is not installed, even though it is
By fatcharlie in forum Newbie / General discussionsReplies: 3Last Post: 13th Dec 2011, 09:44 -
Ilo DVDR04
By 2003 Hayabusa in forum Newbie / General discussionsReplies: 4Last Post: 2nd Sep 2010, 14:48 -
Need files to update ILO DVDR05/ZU cant find anywhere
By strbyz1 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 22nd Aug 2009, 21:48 -
Ilo DVDR04 replacement drive
By emyly7 in forum DVD & Blu-ray RecordersReplies: 11Last Post: 21st Aug 2009, 03:12 -
ILo dvd recorder not cooperating
By jhayes in forum DVD & Blu-ray RecordersReplies: 9Last Post: 9th Dec 2007, 10:06
