Hi Baldrick,
Look up the entry "GIGO" (the abbreviation). It says see "Garbage In Garbage Out", which is a hyperlink to that entry.
Click on the hyperlink and it takes you where clicking "All" takes you - to the start of the list ("0", "A" etc.)
There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
works fine in explorer 6 but not in crappy firefox. it is case sensitive.
Ah, it'll be crappy firefox that I'm using...
Carpe diem.
Could the definition for h264 be added to the glossary?
By yoda313 in forum FeedbackReplies: 2Last Post: 27th Jun 2010, 07:50 -
VHS into Imovie (HD6) with Pyro AV Link Problem
By MacInMass in forum MacReplies: 3Last Post: 9th Apr 2009, 08:25 -
Can anyone send me a link on how to fix an out of sync problem?
By gomer in forum Newbie / General discussionsReplies: 2Last Post: 10th Nov 2007, 23:47 -
Such thing as dual link to single link DVI-D cable?
By Mizkreant in forum DVB / IPTVReplies: 1Last Post: 14th Jul 2007, 05:51 -
Intermittant problem with link to last post.
By gadgetguy in forum FeedbackReplies: 6Last Post: 14th Jun 2007, 16:55
