hey guys, i have a problem with xvcd's and cnat really find ne information on it that would be helpful. was wondering if anyone had ne experience with it or kno how to fix my problem. Have Cd's in XVCD and it works fine on dvd player, but wont work on computer.. like computer wont really read it.... was wondering how i would go about finding a way to rip the xvcd ONTO my computer??? if ne1 could help.. it would b much appreciated.
Results 1 to 18 of 18
sorry it shouldnt be that hard to read it, most of the words are fine. I had a friend who tried six different cd-rom drives.. which all didnt work, does anyone have ne other suggestions
i really need to find a solution.
clean the disc.
try the freezer trick.
Does it even show up in Windows Explorer or is it just as if Windows never even recognises that there's a disc there ?
Or does it show up in Windows Explorer, but when you go to access it you get an error message ?If in doubt, Google it. -
the disc is perfectly fine... its retail..... freezer wont do crap for it.
the disc is in it, it just shows nothing, no folder, not file inside the cd. -
yeah, it shows the label, but nothing in it. the read speed of xvcd is about 1.2mb/s that is the program dvd player can read it, but explorar can not, vcd is about 160/s
So when you said before that "its retail", you've purchased this disc ?
I'm thinking that if it has been purchased, there may be some sort of autorun running when you put the disc into the computer, to give you the impression that you can't copy the disc.If in doubt, Google it. -
well.. if there was autorun, wouldnt u at least be able to see like the source of the files...
If there is an autorun program on the disk you can keep it from running if you hold down a shift key while inserting the disk into the drive. Unfortunately, if some software has already been installed on your computer from previous insertions, this won't work. You'll have to find an uncontaminated computer to try it out on.
is there anyone that mite have had first hand experience.. that way we can be SURE of the exact problem or how to fix it? i will ask my friend to try these suggestions... but they still seem iffy, like not sure if it would work or not.. does anyone kno a definite answer?
Try IsoBuster on the disc, to see it it can find anything.
If you're looking for a way to backup your XVCD, a simple disc copy should do (if it's not copy protected somehow).
And remember that that "X" can stand for anything - it just denotes that it doesn't conform to the VCD standard (Which would make every CD that isn't a true VCD to be a XVCD...)
/Mats -
Originally Posted by Mikewho19
No-one has mentioned the PICNIC yet either, BTW.If in doubt, Google it. -
Mikewho19,
is there a thick blank looking ring near the center on the
read "silver" side of the cd? Does the silver side of the cd
look different to other cd's, if so how? -
jimmalenko, sry i dont meant to get u mad or anything... and u've been very helpful.... i know not alot of people have this answer.. thats why i am still looking. I dont mean to sound disrespectful when i asked again... i'm just giving it my all because i need to kno real bad how to fix this problem.
Originally Posted by jimmalenko
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
