I have a small problem with my PVR2000. The video capture works fine...
My problem happens when I have more than 1000 seconds of audio! Actually, the audio portion disappears after 16 minutes 40 seconds, every time!
The signal is coming from my VCR, which is connected to the PVR2000 card. As long as I go in short bursts (like I said, under 16m 40s) everything is fine. But that is no way to live!
I am sure that there is an easy setting that I need to change, right guys... right? I have installed "the latest" drivers - that tends to solve most other problems, but no go.
Peter
Results 1 to 1 of 1
Philips DVP 3360/05 - Maximum file size when using USB
By jeffdavies in forum Newbie / General discussionsReplies: 2Last Post: 9th Aug 2010, 04:31 -
TMPGEnc Maximum File Size for Authoring?
By cym in forum Authoring (DVD)Replies: 3Last Post: 26th May 2010, 01:55 -
TMPGenc DVD Author 3 Maximum Size
By Shadowofthedarkgod in forum Authoring (DVD)Replies: 5Last Post: 6th Apr 2008, 18:59 -
Leadtek Winfast pvr2000 (retail)
By fulgur in forum Capturing and VCRReplies: 7Last Post: 4th Nov 2007, 09:05 -
Is there a maximum resolution or size for jpgs imported into Vegas 7?
By nzo in forum Newbie / General discussionsReplies: 2Last Post: 8th Oct 2007, 20:18
