I did a quick search but I am looking for a simple answer. Some DVD's that I want are only in PAL format. Can I at least play them on my computer screen/projector with VLC or something? I have all the normal DVD tools used by this forum's members.
Results 1 to 12 of 12
All computers that have DVD players can playback both PAL and NTSC DVDs. If you intend to watch the DVD on a computer you can get either format.Originally Posted by jazzman
Also, if Your TV set supports both systems then You can watch the DVD on a TV from PowerBook..
or you could just go about a PAL to NTSC conversion i suppose
You can convert the DVD format over to NTSC with DVD Converter (part of the MPEG2WORKS package $10 shareware). I recently converted a PAL dvd to NTSC, the process took about 3 1/2 hrs start to finish. The conversion with DVD converter took 3 hrs and to place functioning menus with DVD Studio Pro took 1/2 hr. The picture quality is actually very good too.
Conversion is fine if you cant afford other options. My suggestion is to buy a DVD player that converts PAL to NTSC and region free. I just got the Philips DP642, a DVD/SVCD/VCD/MP3 player that plays MPEG-4 AVI files as well as data CD/DVD with MPEG1/2 files. A simple key combination from the remote makes the player region 0. All that for $62.
Serbian, you out there? How does DVD Converter handle subtitles? Most of my PAL DVDs are subtitled. What's the process for keeping these?
Thanks. -
Unfortenatly, You have to re-author Your DVD again after the conversion and add subtitles manually...My little helper tool does not handle subs...
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
DVD players that play PAL & NTSC - do you need a PAL television?
By ibzomie in forum Newbie / General discussionsReplies: 9Last Post: 12th Dec 2010, 20:53 -
my panasonic standalone dvd can't play pal dvds...but can play pal svcd's
By stoico1 in forum Newbie / General discussionsReplies: 0Last Post: 9th Sep 2009, 16:46 -
playing PAL Hi8 tapes in NTSC camcorder output to PAL DVD recorder?
By interlooper in forum Capturing and VCRReplies: 2Last Post: 17th Jan 2009, 14:36 -
convert PAL HDTV 1080i -> PAL DVD 576i
By halsboss in forum Video ConversionReplies: 0Last Post: 20th Sep 2007, 21:13
