I have been authoring dvd's for a while now using divx and xvid files. I extract the audio as wave and then convert to AC-3 (2.0) using Besweet. I was wondering if there was any way to convert this audio into 5.1 audio and if such programs like TmpGenc DVD Author would even take such audio. Thanks in advance for any help that may be offered.
Results 1 to 9 of 9
for stereo->5.1 methods check out the audio forum at doom9.org. There are quite a few explained in detail. Not sure if Tmpegenc will accept 5.1 audio. I'm afraid not though.
Dvd-lab pro should though.Sorry, I had to go see about a girl -
There are ways of converting stereo into 5.1 and there are plenty of authoring proggys that will accept it. But is it worth it?Originally Posted by SoCalMK
With a lot of effort you can maybe get something that crudley simulates 5.1 surround sound, but it won't be the real thing. With a simple conversion all you will do is waste a load of bitrate. -
Originally Posted by bugster
Good point. I was waiting for someone to say something like that and confirm it so that I wouldn't waste my time. Its always a temptation of mine when working on a project to do too much, way beyond necessity. Thank you all for your suggestions and advice. -
If your audio source is a 2 channel movie, then the effort will be huge, and only worth it if you want to showcase your audio mixing talents.
Having said that, it can be fun to try to create a 5.1 mix for a short clip, simply for the experience.
In answer to some earlier guessing, both versions of DVD Lab will accept AC-3 5.1 The Pro version will allow you to add multiple audio tracks.Read my blog here.
TDA will happily accept 5.1 chanel AC3 audio (i dont even have the Ac3 plugin for TDA).
The only problem I get with TDA and AC3 (wether 2 or 6 chanel) is you do not hear the audio on preview (does the plugin allow you to hear the preview?..anyone). -
Ulead DVD Workshop will author 5.1, hardly worth the purchase price if you already ahve authoring software your satisfied with.
Yes, it does (I bought the TDA + AC-3 plugin)Originally Posted by monzie
Authoring DVD - 5.1 audio
By blueznl in forum Authoring (DVD)Replies: 4Last Post: 3rd Mar 2011, 17:25 -
separating audio and re-authoring
By joecass in forum Newbie / General discussionsReplies: 1Last Post: 23rd Dec 2010, 10:37 -
Authoring with more than 8 tracks of Audio
By RefresherEllie in forum Authoring (DVD)Replies: 9Last Post: 2nd Sep 2010, 23:33 -
Authoring new HD audio formats
By Sergio MH in forum Authoring (Blu-ray)Replies: 0Last Post: 25th May 2010, 13:33 -
Audio problems with authoring
By moes in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2009, 15:27
