I think I am missing something.
How do I go about deleting files on a -RW recorded in VR mode and also deleting files on a -RW recorded in VIDEO mode?
I've resorted to formating the disk every time, but I don't think I should have to do it.
I tried erasing the disks on my PC, but then when I put the disks in the JVC, it wants to format them.
Results 1 to 12 of 12
I think you have to format the disc every time you want to use it on the JVC because it wants to know what kind of disc it has to deal with (video or VR). I may be missing something too though lol.
Sorry, I had to go see about a girl -
The JVC must format the disc to use it. "Format" does not mean "blank".
My friend has a stand alone burner and when he finalizes he cannot use the rw unless he gives it to me and I erase with my pc burner using nero.
My question is whether there is a way to delete the files without having to format the discs again. For example, with a floppy disk, you have to format it first to use it, but then you can copy files to and delete files from the floppy repeatedly without ever having to format it again. Is this scenario possible with the JVC? -
when you delete the stuff you recorded on the disc I'm assuming it's still recognized by the JVC, is it not? If so try unfinalizing it (it's in the same setting menu as finalize) and see if it lets you use the disc without reformatting it.
Originally Posted by midnightsun
and I also don't see an Unfinalize option; I have FORMAT and FINALIZE -
oh well I meant delete the files on the computer. No way to do that on the JVC (as far as I know) unless you reformat.
As for the unfinalize option, I definitely have it. I should add that mine is a DM-R20 (10+ 80GB HDD). Can anybody owing a 10 check if they see unfinalize in their disc setting menu?Sorry, I had to go see about a girl -
My question is whether there is a way to delete the files without having to format the discs again.Want my help? Ask here! (not via PM!)
Right. I've never used edit->delete on a disc but that should work.
Button that brings up interface on recorder.
Deleting files and directories
By Jomapil in forum ComputerReplies: 11Last Post: 20th Mar 2012, 05:41 -
I need help with Canon Vixia HF R10 HD Camcorder
By Nugrl in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 22nd Dec 2010, 14:40 -
GOTSent deleting files upon completion
By draco_nite in forum Video ConversionReplies: 1Last Post: 2nd Nov 2010, 10:16 -
Help!!! .mov files from Jvc hd200 and fcp5? is it possible?!!
By Chris Yule in forum EditingReplies: 3Last Post: 22nd Mar 2010, 12:46 -
JVC .TOD Files, MPEG2 and Deinterlacing
By Cralis in forum Newbie / General discussionsReplies: 37Last Post: 14th Nov 2009, 14:09
